Old Apr 08, 2012, 10:15 AM
umcosta is offline
Find More Posts by umcosta
Joined Mar 2012
Converging thrust vectors - Quad design
Hey guys,
Has anyone ever tried to tilt/angle the rotors to help stabilizing the aircraft? If you look at De Bothezat design, it does use this principle. Here is a picture illustrating the concept:
umcosta is offline Find More Posts by umcosta
Old Apr 08, 2012, 10:40 AM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
My $.02 - It is a very old idea that as far as I have seen provides no benefit. It seems like a good idea because it is simple and intuitive. But given the level of sophistication and speed on the closed loop in a controller there is not enough benefit to give up the loss of lift and flight time.
milo12 is offline Find More Posts by milo12
Old Apr 08, 2012, 10:54 AM
AdaptedEye is offline
Find More Posts by AdaptedEye
Joined Mar 2012
Wouldn't that only apply in a ground effect situation?
AdaptedEye is offline Find More Posts by AdaptedEye
Old Apr 08, 2012, 06:45 PM
umcosta is offline
Joined Mar 2012
Ground effect might interfere in a different way, but in theory this principle would still apply.
Quite possibly.
Old Apr 08, 2012, 07:40 PM
Woodchuck12 is offline
Find More Posts by Woodchuck12
What? I was too busy flying...
Woodchuck12's Avatar
Joined Jan 2011
I have thought about it, but just thought it added a little more complication than is needed on these aircraft.
Woodchuck12 is offline Find More Posts by Woodchuck12
Old Apr 08, 2012, 07:46 PM
Joined Mar 2012
http://www.rcgroups.com/forums/showthread.php?t=1622447
Check out that thread. Not really the same idea but...
Discussion blitzrcworks 5 channel f16 with thrust vectoring ramboner Foamy EDFs 9 Aug 06, 2012 11:19 AM
Discussion Cyclic vs. Thrust vectoring? GreenAce92_v2 VTOLs 29 Mar 09, 2012 12:58 PM
Help! 5Ch BlitzRCWorks F-16 Pro 3D Thrust Vectoring 64mm EDF justincredibleg Electric Ducted Fan Jet Talk 4 Mar 02, 2012 11:28 PM
Sold Twin 70mm SU-47 w/360 Degree Thrust Vectoring Orion Pax Aircraft - Electric - Jets (FS/W) 4 Feb 26, 2012 11:40 AM
Discussion An idea/design for a vector thrust and aileron only pusher prop jet GreenAce92 Foamies (Scratchbuilt) 0 Feb 26, 2010 11:29 PM
