Old Feb 17, 2012, 08:52 PM
flycatch is offline
Find More Posts by flycatch
United States, CA, Barstow
Joined May 2004
Question
YS 140 Sport
Need some help with tuning this engine. I purchased this engine NIB from a modeler on RCUniverse. Engine arrived as described so I'm eliminating that as a problem. I been taken before buying engines sight unseen.
So far I have run 1.5 gallons of Byron 20/20 fuel through the engine using a OS F type glow plug. It is turning an APC 15X12 propeller and the engine is mounted inverted.
At WOT I'm able to adjust the HS needle valve with no problem but when I return to idle for adjustment at the low end I'm unable to get the engine to idle. At idle position it will slowly loose RPM and quit. This is an indication that it is too rich. When I lean it out in small increments it does the same thing but in less time. Either I'm doing something wrong or the metering system of the engine is defective.
I need some advice before I return this engine to the repair facility.
flycatch is offline Find More Posts by flycatch
Old Feb 18, 2012, 08:52 AM
needlenut is offline
Find More Posts by needlenut
Joined Jun 2011
Flycatch hope I can help with your YS140. Setting the low end needle is in reverse of most other engines (2 strokes anyway) to richen turn clockwise, to
lean out turn counter clockwise.
needlenut is offline Find More Posts by needlenut
Old Feb 18, 2012, 12:42 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Yes, the low speed on a YS is actually an air bleed. The manual explains how to adjust the idle mixture.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Feb 20, 2012, 03:05 PM
flycatch is offline
Joined May 2004
Greg
The manual does not explain fully what most be done before the LS NV has any effect. I discovered that the barrel valve most almost be fully closed before the metering system at idle comes into play. This the manual fails to address.
Old Feb 20, 2012, 11:03 PM
oskartek is offline
Find More Posts by oskartek
Curmudgeon at large
oskartek's Avatar
Cedar City, Ut.
Joined Dec 2009
This link will teach you almost all you need to know about tuning YS engines,
http://www.geistware.com/rcmodeling/...er/ys_main.htm
Happy flyin' Oscar
oskartek is offline Find More Posts by oskartek
Found YS 140FZ or YS 140 Sport flycatch Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 01, 2012 11:44 PM
Sold YS FZ-140 Sport engine Brand NEW NIB pilot1211 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 27, 2012 03:07 PM
For Sale Carl Goldberg Extra 300 w/YS 140 Sport (less than 10 flights) JCatRC Aircraft - Fuel - Airplanes (FS/W) 1 Jan 20, 2012 11:49 AM
Sold YS FZ-140 Sport engine ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 21, 2011 08:44 AM
YS 140 sport vs Saito 180 RedWaco Engines 1 Feb 12, 2003 07:15 PM
