This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jul 12, 2013, 01:03 AM
choochoo22 is online now
Find More Posts by choochoo22
Rick
United States, CA, Oceanside
Joined Mar 2011
Originally Posted by Geoff2005 View Post
Was intending on separating, so cutting the read wire between Rx and Guardian and joining the BEC on the Guardian side, so only Black and Signal wires common between Rx and Guardian
Should work but consider that you are creating another point of failure. If either the bec in the ESC fails, or the external bec fails, the model crashes. Unless you really need the extra power you should probably use just the external bec, which I assume is stronger. It can be connected either to the Guardian or the receiver but you should disconnect the red wire from the ESC.
choochoo22 is online now Find More Posts by choochoo22
Old Jul 12, 2013, 05:19 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I have a large aircraft wired exactly that way and it works excellent. I used a large BEC for receiver power that has two power output wires so I had to use two Y connectors on the Guardian. I think that’s the best way to do it, as power spikes from the servos won’t be able to cause a brown out.
I will definitely use that method when I build another large airplane.
RC Man is online now Find More Posts by RC Man
Geoff2005 is online now
Find More Posts by Geoff2005
Geoff2005's Avatar
Perth, Western Australia
Joined Jul 2006
Originally Posted by choochoo22 View Post
Should work but consider that you are creating another point of failure..
Good point!
Geoff2005 is online now Find More Posts by Geoff2005
Old Jul 12, 2013, 07:25 AM
JohnET is offline
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Per the Guardian manual, here are 2 methods we recommend to provide additional current carrying capability;
Receiver Connection Harness Load Capacity
When connected typically, the Aileron lead of the Guardian’s receiver connection harness takes power from your receiver, and this powers the servos you have connected to the Guardian. The Receiver Connection Harness is easily capable of handling the power requirements of typical analog and digital servos. However, if the servos you have connected to the Guardian are very large, and/or have a combined current draw of greater than 5 amps, an additional power cable is required. Note that if your BEC or receiver battery is rated at 5 amps or less (the vast majority are), a backup cable should not be needed. Note also that the Aileron lead of the harness should not be excessively warm after flying, which could indicate that backup power is needed. If the servos you have connected to the Guardian draw greater than 5 amps all together, there are two ways to supply additional power to your servos, which will provide additional current carrying capability to the servos you have connected to the Guardian:
1) If you are not using all the servo output connections on your
Guardian, a male to male servo wire (with the signal line cut!)
can be connected between a free servo channel on the
Guardian, and a free channel on your receiver.
2) If all the servo connections on the Guardian are being used, a
male/male/female Y cable (ET p/n CAB-Y-1 or similar) with
the signal line cut can be used to provide additional power to
the servos, as shown in Figure 3.
Also, here is a quick example of how I launch my Funjet in 3d mode.
Eagle Tree Systems 2d 3d Guardian Stabilizer in a Funjet (1 min 14 sec)
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Jul 12, 2013, 11:22 AM
DavidN is offline
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
JohnET .... Too much fun.
DavidN is offline Find More Posts by DavidN
Old Jul 12, 2013, 06:58 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
http://www.youtube.com/watch?v=ahaDx...ature=youtu.be
John,
Well, well, that video sure demonstrates the effectiveness on launching the torque roll prone Funjet.
Bill
Prof100 is offline Find More Posts by Prof100
Old Jul 13, 2013, 08:48 AM
Go4it is online now
Find More Posts by Go4it
Go4it's Avatar
United States, FL
Joined Mar 2004
Has anyone tried one of these? A3 controllers have been around for years but this model is a lot more advanced. I like my Guardian do to it is small. But for a big plane I guess any size will work
http://www.himodel.com/multi_rotors/...rame_card.html
Go4it is online now Find More Posts by Go4it
Old Jul 13, 2013, 09:02 AM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
IMHO there is no relation between the size of the stabilizer and the size of the plane.
Galand is offline Find More Posts by Galand
Old Jul 13, 2013, 01:30 PM
ogg2000 is offline
Find More Posts by ogg2000
Joined Jun 2013
Mounting Updside Down
Here's a thing...
No matter what I do my ET Guardian does not tolerate being mounted upside down. It appears to reset trims/level flight and correction works properly on the ground. When I fly it and go into 2D mode, it instantly flips inverted, level and slightly nose down and stays there with hands off. 3D mode seems OK but I'm not 100% sure.
I swear I'm on v1.18 but I'll downlaod it again.
Mounted right way up it's working OK in 2D and 3D - I even saw big roll oscillations, so have the gain way down now.
Any ideas, anyone.
Dave
ogg2000 is offline Find More Posts by ogg2000
Old Jul 13, 2013, 05:19 PM
Rick
Joined Mar 2011
Originally Posted by ogg2000 View Post
Here's a thing...
Any ideas, anyone.
Dave
Even V1.17 shouldn't do that if properly reset, but do get V1.18.
Try resetting the level again. This time be very certain to look for the confirming twitch from the Guardian after the reset. If it doesn't give you that confirmation then you haven't done anything. Don't be in a big hurry with the switch, 15 seconds is plenty of time. Pause about a second in each mode.
You should be able to test it on the ground. With the plane powered up and sitting on its wheels/belly, just activate 2D. If all is well there might be a small surface movement, but not much. If the ailerons go to full deflection the Guardian hasn't accepted the reset.
If that doesn't work hook the Guardian up to the PC. With the Guardian inverted and held approximately flat, click the "factory reset" button. It should be OK to do this with the unit in the plane if that is convenient. It doesn't need to be perfectly flat, just not cockeyed. Afterwards don't forget to reinstate any settings you may have made. I would recommend un-checking the flaperon box and the CSS box and setting the stabilization roll angle to 80°. Click OK and disconnect the USB. Now try the level setting again as you did before and watch for the twitch.
Old Jul 13, 2013, 09:17 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I used velcro to mount my Guardian.... it seems/feels stable enough - a good amount of damping whilst being 'fixed' well.
At least it seems so to me....
Is that a known good idea, of bad idea? LOL
I am about to head out (soon.. 1 hour or so) with a small test plane to see how the Guardian works....
PeterVRC is offline Find More Posts by PeterVRC
Old Jul 13, 2013, 09:36 PM
Rick
Joined Mar 2011
Velcro should work fine in most electrics, that's what I use without trouble. Some users with wet power have needed more vibration damping.
Old Jul 13, 2013, 10:04 PM
PeterVRC is offline
Joined Nov 2006
Thanks... I will see how it all goes...
It is a good.. or bad.. test day!! VERY blustery winds, which I would not even bother going to fly anything in normally! I know I can fly it ok even in strong winds (950mm F4-U Corsair), so I guess as long as that first part works (flying with no Stabilisation) then the next tests will give the Guardian a tough workout!
(I have gain and mode channels on it)
Old Jul 14, 2013, 01:11 AM
ogg2000 is offline
Joined Jun 2013
Thanks for the reply. The Guardian accepts the resets and shows all the correct deflections on the ground i.e. all the surfaces move correctly and are neutral in the position it was reset. The twitches are as expected too. I've been meticulous with the resets before flight, and done it loads of times. Tried both flaperon modes too. Turing it around was my last resort, but at least it worked. I had to change the pitch and yaw directions on the pots when I turned it over, which is expected.
Everything looks normal on the ground, but in the air it's different. I just can't explain it - if you turn it over on the ground, you can see the big aileron deflections to flip it over..... The only difference in the air is the motor is running, but it's the same even when at idle.
Dave
Old Jul 14, 2013, 09:16 AM
unknownflier is offline
Find More Posts by unknownflier
you-know-me ...
unknownflier's Avatar
United States, CA, Redlands
Joined Jul 2013
so with my guardian, i could initialize it in a level orientation, then position it in a vertical (straight up plumed) position, flip it to 3d and wing-toss it in almost any direction and have it hover, as long as proper throttle was applied. then just figure out how to manage torque rolling which will occur faster and faster the closer your plane gets to perfect a vertical. using the aileron to stop torque rolling will break the 3d hold and when releasing the stick 3d will re-engage but it will allow the control surface to return to neutral allowing the one directional torque rolling to resume. that's how it should work, right?
thanks,
uf
unknownflier is offline Find More Posts by unknownflier
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
