Old Jan 20, 2012, 01:32 PM
Dnegel05 is offline
Find More Posts by Dnegel05
Joined Oct 2011
My weekend Quad project.
PARTS
Body measures 13.5"x13.5" (3/16" Plywood and CD's)
Landing Gear - (foam balls zipped tied)
Speed Controls - Turnigy 10amp ESC's
Motors - EMAX CF2805
Batteries - Turnigy 2200mAh approx 20-30c
RX - AR6100e
TX - DX6i
Controller - FY90Q Pro
Props - GWS EP5030x3
Top - plastic bowl
ABOUT THE BUILD
I cut the parts with my Dremel 200 which was slightly under powered but finished the job. I would really like to invest in CNC router at some point. I started to build a power harness something I actually enjoy doing but I opt out to save connectors and wire for a new build. My Turnigy 5000mAh pack just came in yesterday .
I did not have proper mounting hardware for the props so I decided to put heat shrink on the motor axles push the props down over the heat shrink then I added a few layers of heat shrink to make caps along with a dab of CA. I inspect them before each flight and this method seems to be working perfect right now. I have to really do some outdoor aggressive flights to really find out.
The FY90Q does not like vibration at all so I decided I would fly a few packs before adding the top to compare since I would be mounting the cover with velcro directly to the FY90Q. After putting a few packs through I did not notice any difference in the flight so as of right now it works fine with the plastic bowl on top.
FLIGHT
The motors are a little loud but the control is awesome it flies as if it were on wires. Very stable, even in ground effect approx. 5 inches or so. I would like different props not really sure if I like the tri blades for this model. I hope you enjoyed this post. Take care, best wishes !
Dnegel05 is offline Find More Posts by Dnegel05
Old Jan 20, 2012, 06:31 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by Dnegel05 View Post
PARTS
RX - AR6100e
TX - DX6i
Top - plastic bowl
Interesting motor choice for a mini quad. What kv are they?
Erknie is offline Find More Posts by Erknie
Old Jan 20, 2012, 08:17 PM
Dnegel05 is offline
Joined Oct 2011
Erknie,
They are 2800kv motors. It has a lot of power just need to add a little expo and decrease pitch and roll slightly before making these adjustments it was uncontrollable afterwards extremely stable and very powerful.
Discussion Travel Spider Quad Project panos2408 Multirotor Talk 0 Nov 24, 2011 03:09 PM
Discussion Quad Copter project Ben_1982 Multirotor Talk 3 Nov 04, 2011 04:03 PM
Discussion new project this weekend cruzroy Mini Helis 4 Sep 20, 2011 04:09 PM
Discussion Project 8 motor Quad Niste Multirotor Talk 0 May 09, 2011 10:33 AM
