Old Jan 11, 2012, 11:29 PM
n3o is offline
n3o
Find More Posts by n3o
n3o
Joined Jul 2011
Corostang help
Hello all!!
I checked out the free plans at STTB, and plan to build a corostang,a few questions:
1)The instructions mention that coroplast varies slightly from brand to brand. What type of coroplast usually works best for spads? e.g the industrial name of the plastic.
2)The author recommends HS 81 mg servo, and I have HS 325 HB =P almost twice the weight, will it be ok to work on that?
3) I plan to put on a landing gear , simple 3 wheel rods. What can be the ideal position for that?
regards,
n3o
n3o is offline Find More Posts by n3o
Old Jan 12, 2012, 08:41 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The servos would be OK.
The two main wheels on the landing gear should be aligned to about where the leading edge of the wing is. You could bend one length of piano wire to make the main gear from and fasten it to the forward bulkhead just in front of the wing in the fuselage.
The tail wheel of course is back and hooked up to the rudder in some manner.
earlwb is offline Find More Posts by earlwb
Discussion Help Help Help Have to order stuff tonight PetroMonkey FPV Talk 12 Dec 05, 2011 08:51 PM
Discussion help!!help!!help!!proboat shockwave 36 flex shaft regin20 Racing Boats - Internal Combustion 5 Mar 31, 2011 03:29 AM
Discussion spad corostang whit tt.36 pro (video) boul69 SPAD - Simple Plastic Airplane Designs 0 Jul 28, 2009 04:35 PM
Discussion spad corostang whit a .36 magnum se boul69 SPAD - Simple Plastic Airplane Designs 5 Jul 21, 2009 08:50 AM
Discussion corostang whit .36 magnum se boul69 Combat 2 Jul 13, 2009 07:24 AM
