Old Jan 03, 2012, 11:51 AM
wantboost is offline
Find More Posts by wantboost
Joined Dec 2011
What extra parts/batteries/charger to get for SOLO PRO II??
I am ordering a SOLO PRO II RTF I am wondering which extra batteries and charger if needed to get?
Also which initial extra parts should i have around that can break easily?(i hear the landing gear is weak is there aftermarket ones that are stronger?)
thanks!!
wantboost is offline Find More Posts by wantboost
Old Jan 03, 2012, 12:37 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
thanks!!
I will get hyperion lipo 1s 130mah keyed slot battery, http://www.clubheli.com/HYPERION-G3-...ry_p_2882.html
For charger, try this one, http://www.clubheli.com/Nine-Eagles-...on_p_2269.html
If you ask for parts, I break 1 x tail blade only. Though I break landing skid but I glued it back.
Here is what I stock parts for SoloPro II,
1. main balde
2. tail blade
3. 2 x main motor
4. 2 x tail motor
5. 1 x landing gear (most of time, you fix broken skid by glue)
for beginner, I suggest the following too.
6. main shaft
7. rotor head
8. swashplate
However, clubheli has SoloPro II EZ bind (without tx) at $50.00, so it's not bad idea to get EZ bind one instead of getting individual parts. At least, you have spare heli to fly in case first broke.
wlee1017 is offline Find More Posts by wlee1017
Old Jan 03, 2012, 03:45 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
thanks!!
The Nine Eagles Wall Charger works well, and with a little modification to the case, you could also use the Trex100s charger, which can also be powered through USB.
My favorite all round battery is the Hobby King OEM 120 mAh "Replacement" battery. Flight times of over 6 minutes, with good climbing power, and these batteries last over 100 cycles or more.
As for the landing gear, it seems some batches are indeed weak, while others are indestructible. If you want to be sure of a crash proof landing gear, nothing can beat the Xtreme one. It adds some weight, but I've yet to hear someone break it during flight.
For other questions you might come up with, this Solo Pro FAQ thread may help: http://www.rcgroups.com/forums/showthread.php?t=1337008
SoloProFan is online now Find More Posts by SoloProFan
Old Jan 03, 2012, 11:57 PM
Joined Dec 2011
1. main balde
2. tail blade
3. 2 x main motor
4. 2 x tail motor
6. main shaft
7. rotor head
8. swashplate
those batteries are out of stock at club heli:
what about these 3 at hobbyking:
http://www.hobbyking.com/hobbyking/s...h_1S_LiPo.html
http://www.hobbyking.com/hobbyking/s...NE4950001.html
http://www.hobbyking.com/hobbyking/s..._GENUINE_.html
so the extreme blades, swashplate and flybar make a differece?
i assume extreme blades will have less flex, same with flybar .
i guess if im gonna get a extra rotorhead i might aswell get the extreme so it doesnt break or will it make all the other peices break instead?
Old Jan 04, 2012, 12:19 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
I agree with SoloPro (with a name like that can you really argue with him?) regarding the hk oem 120mahs. They are great. I get at least 6min and excellent power. Many cycles in now and they are still going strong.
I think this is them: http://www.hobbyking.com/hobbyking/s...NE4950001.html
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 04, 2012, 09:40 AM
Joined Dec 2011
have u tried the other batteries
Old Jan 04, 2012, 06:40 PM
larams is offline
Find More Posts by larams
Joined Oct 2011
The Turnigy 130 has been pretty good so far for me. I think they are $1 each at HK.
larams is offline Find More Posts by larams
Old Jan 05, 2012, 04:01 AM
Sonicg is offline
Find More Posts by Sonicg
Hong Kong
Joined Sep 2011
If you want to buy extra tail motors, it's better to buy the whole tail. First they broke before the engine was worn out, now they wear out before the tail breaks.
My spare parts kit has:
Main shaft
Main engine
Gear
Tails
Landing skids
Tail rotor
My flying space is tight so the tails go quick.
Sonicg is offline Find More Posts by Sonicg
Old Jan 05, 2012, 04:18 AM
Tokyo
Joined Jan 2010
When I get my hot glue gun I'm going to reinforce the tail boom where it goes into the main frame. I've had breaks occur there several times.
Old Jan 05, 2012, 05:26 AM
Sonicg is offline
Hong Kong
Joined Sep 2011
I tried to solve this by putting a piece of cf inside the tailboom. I used old taolbooms foor that. Works quite well so far.
Old Jan 07, 2012, 12:02 AM
Joined Dec 2011
Main shaft
Main engine
Gear
Tails
Landing skids
Tail rotor
should i get the extreme landing skids they look a bit stronger
Old Feb 29, 2012, 07:21 PM
solpro is offline
Find More Posts by solpro
Joined Feb 2012
Regardless if you're a beginner or not I recommend the followings. Way I see things, you will always definitely need more parts. Better to have plenty in stock so you don't have to wait weeks for the parts to come in. Local hobby shops charge too much.
1. At minimum, double of tail boom, tail blade, main blade, main shaft, main gear, linkage and rods, landing gear.
2. Landing gear you might want to have 4 around unless you're very good at landing. The landing gear is very fragile. You might want to check out www.iknosolopro.weebly.com. Good stuff from this link.
3. Because of the cost (affordable) get you at least 3 sets of linkage and rods.
4. Definitely if you want to have fun get yourself at least 4 batteries.
5. A must have is the dual battery charger for 14 bucks. Unless you want to drain your transmitter you want this bad boy charger. Trust me on this.
This bird is very sturdy to a certain point. Things will break. Let just say I've crashed my bird so many times but still with parts have it flying within minutes.
solpro is offline Find More Posts by solpro
Question what charger parameters for AA batteries with orion advantage charger le varan Batteries and Chargers 4 Dec 17, 2011 01:27 PM
Sold E-Flight Blade CP Pro w/2 li-po batteries and extra parts $120 shipped UHATEIT Aircraft - Electric - Helis (FS/W) 5 Sep 15, 2011 12:26 PM
For Sale NEW Blade mSR RTF and/or Extra charger, 3 LiPo batteries, extra spare parts Nikoli25 Aircraft - Electric - Helis (FS/W) 0 Aug 11, 2011 10:20 PM
Discussion Good Place in the U.S. to get Solo Pro Parts? spessx Micro Helis 3 Feb 28, 2011 02:52 PM
For Sale RTF Solo Pro II with radio and battery $65 Shipped! Use MSR/Eagle Nine batteries! kctrading Aircraft - Electric - Helis (FS/W) 3 Jun 24, 2010 11:34 PM
