Old Dec 30, 2011, 04:45 PM
fly Frontier is offline
Find More Posts by fly Frontier
Electric foamy flyer
fly Frontier's Avatar
Chandler, Arizona
Joined Apr 2010
Help!
Hitec Optic 6 2.4 Sport Problem
Today my Hitec Optic 6 2.4 Sport radio is acting funny. I Turn Tx on and then Rx on the plane, I get a connection beep from the tx and lights indicate a link. However all the servos shoot in one direction and stop, also the motor makes a few beeps i have never heard. No control surface or motor response. If i go into programing and adjust the Sub Trim of the servos, they respond to the adjustment but still no stick movement response. Also I believe most Program mixes etc... do work.
I have re-Binded the receivers and tried it on different airplanes and my Heli. same problem. Could this be a factor: When i plugged in my 7.2v lipo, I accidently plugged in the polarity backwards, turned it on, quickly turned it off, then fixed it, and thats when the problem started.
What can i do? is my radio fried? can i get a warrenty? Also i did not purchase this radio, i won it in a contest.
Thanks for the help
Daniel
fly Frontier is offline Find More Posts by fly Frontier
Old Dec 30, 2011, 07:34 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Hitec Optic 6 Sport - Reversed polarity.
I have re-Binded the receivers and tried it on different airplanes and my Heli. same problem. Could this be a factor: When i plugged in my 7.2v lipo, I accidently plugged in the polarity backwards, turned it on, quickly turned it off, then fixed it, and thats when the problem started. What can i do? is my radio fried? can i get a warrenty? Also i did not purchase this radio, i won it in a contest. Thanks for the help Daniel
Reverse polarity damage is instant, no second chances nor user fix.
After correcting connector and switching on, damage usually confirmed by both a higher voltage than pack in use
e.g. 2S Lipo will probably show 10.4 V on lieu of 8.1<8.4, and a weaker LCD screen display, especially when viewed at an angle.
Contact: Hitec Warranty & Service
Service Form
Note: Hitec USA only services North/South America and Canada.
All other countries see appropriate distributor for service.
If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
To avoid future errors, suggest copy and insert the sticker shown:
Hitec Aurora, Eclipse, Flash, Optic & Prism series TX - Lipo and Field / Fast Charging
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Dec 30, 2011, 07:39 PM
Chandler, Arizona
Joined Apr 2010
Thank you for your reply. will contact on monday. they were closed today
Old Sep 26, 2014, 01:14 AM
goodwrrench is offline
Find More Posts by goodwrrench
United States, AZ, Kingman
Joined May 2014
having same issue with my optic 6 sport but i did not connect my battery backwards and suggestions????
goodwrrench is offline Find More Posts by goodwrrench
Old Oct 03, 2014, 11:37 AM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
I would suggest you give us a call to troubleshoot. (858) 748-6948
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Sold Hitec Optic 6 Sport 2.4 radio $80 JoeR Aircraft - General - Radio Equipment (FS/W) 16 Jan 12, 2012 09:25 PM
Help! Hitec Optic 6 2.4 Sport Problem. HELP fly Frontier Radios 1 Dec 30, 2011 07:47 PM
Cool Vendo radio hitec optic sport 6 ch 2.4 ghz markk25 Mexico 1 May 23, 2011 03:30 PM
Discussion Looking for a micro receiver compatible with Hitec optic 6 sport 2,4 paramarc Electric Plane Talk 3 Apr 09, 2011 03:14 PM
Help! hitec optic 6 2.4 vs optic 6 sport 2.4 shanet1975 Radios 13 Nov 29, 2010 04:06 AM
