Old Aug 06, 2011, 03:36 PM
Doc Watson is offline
Find More Posts by Doc Watson
Doc Watson's Avatar
UK
Joined Mar 2000
F35b plans FREE!!!!!!
It will probably be another 10 years before I build mine so I thought I would share my plans for a 1:9th scale which uses 3 90mm EDF's.
Plans are in corel draw format and I would appreciate if anybody could convert to DXF or another usable format for all to use.
There are quite a few layers and the design took about 2 years to complete, still dont know if it works.
Enjoy......
Andy
Doc Watson is offline Find More Posts by Doc Watson
Old Aug 06, 2011, 06:13 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Hi Andy,
I gave it my best shot, but I was unable to convert it to a usable DXF or DWG file.
I was able to open it in Adobe Illustrator, so I could see and appreciate all your hard work.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Aug 07, 2011, 10:09 AM
daniel lö is offline
Find More Posts by daniel lö
Sverige, Hallands Län, Varberg
Joined Jul 2006
AH, not even Adobe Illustrator cs5.1 let me open this file
daniel lö is offline Find More Posts by daniel lö
Old Aug 07, 2011, 12:45 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
This is a Corel Draw file. I had to open it with Corel Draw 12 or later.
JimDrew is offline Find More Posts by JimDrew
Old Aug 07, 2011, 04:21 PM
texbird is offline
Find More Posts by texbird
texbird's Avatar
USA, TX, Austin
Joined Jan 2011
when i try to open this in paintshop i get a corrupt file message
texbird is offline Find More Posts by texbird
Old Aug 07, 2011, 09:08 PM
Wisdumb is offline
Find More Posts by Wisdumb
Wilsonville, OR
Joined Jun 2010
I was able to open the file with Illustrator CS3 without any issues except for an unrecognized font.
Wisdumb is offline Find More Posts by Wisdumb
Old Aug 07, 2011, 09:46 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Same here with Illustrator CS4. I was able to zoom in and look at the plans. The problem was when I tried to export it to DXF/DWG. The resultant artwork was unusable because all of the curves were distorted.
Old Aug 07, 2011, 09:59 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Same here with Illustrator CS4. I was able to zoom in and look at the plans. The problem was when I tried to export it to DXF/DWG. The resultant artwork was unusable because all of the curves were distorted and all the artwork seems to be all in one layer.
Andy,
I am able to convert the file over to an Adobe Illustrator format and it preserves the layers. If you'd like a copy of the file, let me know.
I am able to save it in any version of Illustrator up to CS4.
Dan
Old Aug 07, 2011, 10:39 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
I will see what Corel Draw XV will export as.
Old Aug 09, 2011, 10:30 AM
Doc Watson's Avatar
UK
Joined Mar 2000
I will try again to export to DXF from my ancient corel draw 9....
Andy
Old Apr 22, 2012, 12:37 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Bump
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Apr 22, 2012, 01:24 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Thanks for sharing! Very generous of you. I don't have any s/w that can open the files, so I'll defer to otehrs for conversion.
Phil Lin
PhilLin is offline Find More Posts by PhilLin
Old Apr 24, 2012, 12:23 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I had my test bed worked with 2 90mm fans and a 60mm ducted out to the wing tips with a micro servo opening and closing the ducting to control roll. I need an airframe to try it all out in, but think I would do a quick and dirty foam version first.
First Hover Test
90mm F-35 Test Bed Succesful Hover!!! (0 min 42 sec)
Tweaking the gyro
90mm F-35 test hover 2 (0 min 44 sec)
Roll Test
F-35 Roll Duct Testing (0 min 36 sec)
Tumbler is offline Find More Posts by Tumbler
Old Apr 24, 2012, 12:42 PM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
I opened the file in Inkscape: no texts but the drawings probably have everything. Not real easy to read
Here's a PDF file:
perttime is offline Find More Posts by perttime
Old Apr 24, 2012, 03:54 PM
Joined Jun 2007
First Hover Test
http://www.youtube.com/watch?v=6Fkfq...feature=relmfu
Tweaking the gyro
http://www.youtube.com/watch?v=to_x-lF20vc
Roll Test
http://www.youtube.com/watch?v=hEEAt...feature=relmfu
Awesome job, you using a quad controller or mixes and gyros?
CJ
Discussion Free plans VincentC Scale Sailplanes 69 Apr 13, 2013 01:27 PM
Discussion Sbach 342 Full fuse Free Plans bbjsw10 Foamies (Scratchbuilt) 142 Apr 07, 2012 02:48 PM
