Old May 20, 2001, 10:08 PM
Electric Columnist
Greg Gimlick's Avatar
Fuquay Varina, NC
Joined Dec 2000
Mine is showing about 10.6 volts after the first two charges.
Greg Gimlick is offline Find More Posts by Greg Gimlick
Old May 21, 2001, 12:24 AM
Austin, Texas USA
Joined Mar 2001
Eclipse Voltage after a charge
I posted this in "Ask Mike" for an answer:
Mike-
I have a Flash TX that registers over 11 volts when charged. I have an Eclipse that only registers about 10.2 volts freshly charged. I switched the bateries, and the readings were the same. So, are the voltage readings THAT inaccurate, or is it that the Eclipse draws that much more current and drops the voltage?
What does everybody else's Eclipse register after a charge? Are you guys getting anything much over 10.2 volts?
Thanks.
sf_247 is offline Find More Posts by sf_247
Old May 21, 2001, 08:46 AM
kevin's Avatar
ohio
Joined Aug 1999
im pretty sure mine showed 11.1 after the first 2 charges.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old May 21, 2001, 02:54 PM
wattsup's Avatar
Canton, MI USA
Joined Mar 2001
I get 11.3 volts "after charge" with my Eclipse as well as with my Futaba 8UAF.
wattsup is offline Find More Posts by wattsup
Old May 21, 2001, 03:00 PM
Mountain View, CA, USA
Joined Nov 2000
I also get in the 10.2--10.5 range. I to tried swapping the battery with that in my Flash 5 with no significant change.
Jim
Jim Winget is offline Find More Posts by Jim Winget
Question resting voltage after charge nevermind Batteries and Chargers 2 Apr 28, 2006 08:43 AM
battery voltage after charge gorbulas Batteries and Chargers 1 Nov 15, 2005 04:28 AM
TP 3s2100 not full voltage after charge? miamiquasar Batteries and Chargers 7 Oct 29, 2005 09:36 PM
3s Lipo...What voltage after a charge? ChuckD Batteries and Chargers 15 Mar 06, 2005 10:43 AM
Battery Voltage after charge ctdahle Batteries and Chargers 0 Feb 15, 2003 09:54 PM
