Old Jul 22, 2014, 02:29 PM
Italy, Tuscany, Grosseto
Joined Feb 2007
New phoenix sea hawk edf 90mm build threads
Hello friends,
today arrived to my home the new Sea Hawk 90mm edf jet from Phoenix (http://phoenixmodel.com/Product.aspx?ProductId=588).
A beautiful jet all balsa construction covered with original Oracover. In these thread I post step by step the construction and finally first fly.
sandrocacciola is offline Find More Posts by sandrocacciola
Old Jul 22, 2014, 02:33 PM
Joined Feb 2007
Characteristics
- Retract gear type: Mechanic retract gear with CNC Suspension Metal Struts (included)
- Radio: 6 - 9 channel . 8 mini hi-torque servo: 2 aileron; 2 flap;
2 elevator; 1 rudder; 1 steering nose; 3 servo retract futaba S3170G (34,5 x 16 x 25,8 mm 9 kg 180 gradi rotazione)
- Servo mount : 13mm x 26mm
- Engine: edf 90mm (not included)
- Gravity CG: 150mm (5,9 in) Back from the leading edge of the wing, at the fuselage
- Control throw Ailerons: Low: 12mm up/down, 10% expo; High: 15mm up/down, 10% expo
- Control throw Elevators: Low: 12mm up/down, 12% expo; High: 15mm up/down, 12% expo
- Control throw Rudder: Low: 20mm right/left, 15% expo; High: 30mm right/left, 15% expo
- Experience level: advanced
- Plane type: Scale Military
RECOMMENDED EDF AND BATTERY SET UP
- EDF: 90mm, Minimum thrust 2.7 kg. Motor out turner 3553- 1500W- 1750KV (not included)
- Lipo cell: 6 cells / 5500 6000mAh (not included)
- Esc 80-100 A (not included)
Old Jul 22, 2014, 02:42 PM
Joined Feb 2007
Designed by Robert, who is technical director of Phoenix. This beautiful jet in scale 1/7.5 is going to bring you the adrenalin, high speed thrilling flights with true jet sound thanks to the new CS XRP 14 fan blades with motor Cyclone Power 6S 1550kv, setup provided by TurbinesRc (http://www.turbines-rc.com/fr/turbin...1550kv-6s.html).
The progress of the assembly of the kit Phoenix is high: the works to be performed are routine: it takes longer time to put all kit details that assembly the structure!
The wings are assembly in two pieces for easy transport to the field.
Old Jul 23, 2014, 06:43 AM
Joined Feb 2007
These is some immages about the kit.
The structure balsa / plywood is very light and the construction work is ordered as we have become accustomed Phoenix.
Old Jul 23, 2014, 06:50 AM
Joined Feb 2007
To understand how Phoenix has worked here are some weights of the structure:
Fuselage 470g
Copckit scale 185g
Two wing 370g
Rudder 60g
Two quote 80g
Gear+struts and whell 255g
Very very light!
Old Jul 23, 2014, 06:57 AM
Joined Feb 2007
The kit Sea Hawk Phoenix includes a series of scale details in plastic that must be applied to the fuselage: front inlet air, antennas, gear and whell compartments. The details must be cut and applied with cyano glue.
Old Jul 23, 2014, 09:25 AM
St. Mary, Maryland, United States
Joined Dec 1996
Looks pretty nice
Keep em coming.
Chris True is offline Find More Posts by Chris True
Old Jul 23, 2014, 10:22 AM
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Looks nice. I'd be interestded in more information on inlet ducting and room for batteries
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Jul 23, 2014, 11:31 AM
union1's Avatar
United Kingdom, England, Sudbury
It's not a bloody Sea Hawk for heavens sake!
It's simply a BAE Hawk. This seems to be a hang-over from an earlier thread.
THIS is a Hawker Sea Hawk...
union1 is offline Find More Posts by union1
Old Jul 23, 2014, 01:07 PM
Joined Feb 2007
Hello!
the model is a Bea Hawk but Phoenix sells it with this exact wording:
"Amazing RC Sea Hawk 90mm EDF"...
Old Jul 23, 2014, 01:19 PM
Joined Feb 2007
The inlet ducting is in epoxy as the tube thrust.
Very well made and that inlet allow to arrive directly the air on the fan. The weight is:
cone thrust 90g
inlet ducting 130g.
I might try to not install the intake to test the performance of the fan. This option would save 150g... I'll think about
Old Jul 24, 2014, 01:53 PM
Joined Feb 2007
Today I installed the retract. For finish my jobs I must waithing the servo: 180 for retract and mini metal gear for aileron. For quote, flap and rudder I used TGY-S712G:
Full Metal gear, alloy case, dual Ball Bearing, 28g, torque At 4.8V: 6.0kg/cm
Torque At 6.0V: 7.0kg/cm. very fluid motion.
Old Jul 24, 2014, 01:56 PM
Joined Feb 2007
For nose gear first must glue the plastic cover compartment and make holes for passage of the rod for the retraction and push/pull of steering.
I forgot: in my website you can find all my review:
http://sandrocacciola.wix.com/modellismonewsrc
Old Jul 26, 2014, 02:32 PM
Joined Nov 2013
nice work Sandro!
you may be interested to hear my impression of this model as i already logged 15 flights in the last 2 weeks.
there us a CG problem. you must do some modifications to get it right.
i took out the pilot figures and mounted the reciver batterry at the tail.
the main landing gear is too much forward, if you put the tail to the ground it stays down. i think i will have to replace the struts with wire ones that will be bent to the rear.
as it is now the landing is jumpy no matter what i do.
flight performance is exelent and with some modifications it will be my best jet
i use Wemotec evo, a HET 58-1970 , and 6s 5000 25c battery
Omri
omri sirkis is offline Find More Posts by omri sirkis
Old Jul 27, 2014, 01:08 PM
Joined Feb 2007
Hello Omri
I saw that jn the manual does not shows the position of the batteries and for these I contacted Phoenix to ask where they thought to put them for have an exact centering CG.
I will let you know. Meanwhile, thanks for the information
New Product Sea hawk scale 1:7 arf edf 90mm MasterP51 Electric Ducted Fan Jet Talk 54 Sep 12, 2014 07:24 AM
Discussion Bae hawk 90mm hobbyking my first edf build thread tobys550 Electric Ducted Fan Jet Talk 1 Mar 01, 2014 11:05 AM
Discussion FlyFly Thunderbird 90mm EDF Build Thread gazza2003au Foamy EDFs 6 Oct 02, 2012 01:41 AM
Build Log JET TENG 90mm HAWK BUILD THREAD Extreme_RC Extreme RC AUSTRALIA 65 May 08, 2012 05:02 PM
Discussion HK 90mm BAE Hawk Build Thread! neversommer Electric Ducted Fan Jet Talk 33 Jan 23, 2012 02:21 AM
