Old Nov 27, 2013, 09:49 AM
Joined Mar 2007
motorising kit for 1/200 Missouri
Now on release,
the motorising sets for the 1/200 Trumpeter Missouri kit,
developed and test by Deans Marine and now added to the
product range
Motorising Kits 4 screw consists of
4 x KYTE Motors
4 x Capacitors
2 x 2.3mm / 2mm MINICOUP couplings
2 X 2.3mm / 2mm Nychrome EXL couplings
4 x 2mm / M4 Minitube EXL propshafts
1 x 148-01 5 blade warship props
1 x 148-02 5 blade warship prop
1 x 147-07 4 blade warship props
1 x 147-08 4 blade warship prop
2 x 2mm Brass bearing tubes BT3M =20mm x 2mm
2 x 2mm Rudder tubes STD = 30mm x 2mm
2 x 2mm STD steel rudders shafts = 70mm
1 x Nylon Tiller arms TA-7
1 x Nylon Tiller arms TA-9
1 x TWIN Motor Mounts vacformed
2 x single L & R motor mounts vacformed
4 X MOTOR CLAMPS A42
4 X FIXING SCREWS M14
1 x 45 mm .055 piano wire Z bend
LASER CUT 1.5MM PLASTIC
1 X SERVO MOUNT
1 X FILLER PLATE
2 x OUTER TUBE SUPPORTS
1 X COFFER DAM SET
2 X BATTERY BOX
1 x C/D of 200 + picture of the installation in our two test models
Similar set up for twin screw with 148 type props
4 screw kit 152..00 twin screw set 81..50 (uk prices)
see our website for details
Regards
Deans Marine
rondean1 is offline Find More Posts by rondean1
Old Nov 27, 2013, 05:19 PM
Sometimes I am the weapon
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
Where's the "economy" 2 and 1 motor versions ( la the Dean's 1/200 Bismarck set) to go along with the "premium" full motor setup?
TRUMPETER BISMARK R/C set up follow on
Doesn't matter to me that a 1-prop Missouri would be... asymmetrical.
Would probably sail in wide circles without corrective rudder trim.
Harquebus is offline Find More Posts by Harquebus
Old Nov 28, 2013, 01:49 AM
Joined Mar 2007
Dear Harquebus
The Bismark is a triple screw boat, easy to do a single shaft with centre prop, more powerfull motor and larger pitch prop, or triple screw set up.
Missouri is 4 screws, so it is centre twin or quad set up, plus she is a much larger model with greater displacement. to fut a single centre shaft would require major hull surgery, not a good idea on a huge injection moulded hull.
Regards
Deans Marine
Discussion trumpeter 1/200 Missouri kit rondean1 Scale Boats 12 Nov 23, 2013 03:54 AM
Sold Ark Models 1:200 USS Missouri Kit, Started ir3 Boats (FS/W) 0 Apr 11, 2013 11:49 PM
New Product 1/200 Uss Missouri Maiden Voyage arkmodel Scale Boats 10 Oct 14, 2008 09:08 AM
Discussion Pics And Videos Of 1/200 Missouri arkmodel Scale Boats 2 Sep 28, 2007 03:17 PM
Discussion Uss Missouri Bb63(1945) 1/200 arkmodel Scale Boats 6 Sep 23, 2006 01:50 AM
