Old May 20, 2013, 09:43 PM
Joined May 2008
Build Log
30" ws x-47b
Hey all,
Been wanting to try to make this plane for a while and I decided to go for it. This is a super budget build and my first scratch build. Please if you have negative comments take them to the helicopter forum .
Foam: $tree Readyboard
Battery: 1000 3S *edit
ESC: HK Red Brick 20A
EDF/Motor: 50mm HK Alloy
Amp: 18A
I made the design myself in SolidWorks and printed out the drawings on 8.5x11 sheets to cut out the foam. Some interesting techniques had to be used to get them right.
Heres the design in SolidWorks:
Currently I have all the foam cut out still working on placement of all the electronics. Heres the airframe:
I will update more as I get farther into this.
Jalm is offline Find More Posts by Jalm
Old May 21, 2013, 09:21 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Looks like a Blended Wing Body. Nice looking plane!
djacob7 is online now Find More Posts by djacob7
Old May 24, 2013, 09:19 PM
Mike Brinker
tr6world's Avatar
SouthEast Michigan
Joined May 2008
Jeff,
Plane looks great, exactly like the drawings..... great job. What do you plan to use to adhere the foam sheets together?
tr6world is offline Find More Posts by tr6world
Old May 31, 2013, 05:43 PM
Canada, ON, Ottawa
Joined Mar 2013
Looks pretty good,you should post the plans if you have them
charly0.0 is offline Find More Posts by charly0.0
Old Jun 08, 2013, 11:01 AM
Canada
Joined Nov 2000
Might consider Glidden 'Gripper' Paint as foam glue. Cheap easy and V good. Albeit it needs to cure for a min of 24 hours, preferably 48.. but it adds serious rigidity to the structure as unexpected bonus.
You may also find that a 40 amp esc is needed for that HK50 mm alloy edf.
30 a is proving inadequate on mine.
Bare is offline Find More Posts by Bare
Old Jan 18, 2014, 11:25 AM
Joined May 2008
Its been a while since I posted on here but lately I have made some good progress.
I do have concerns but am still going forward with the build...
1. I do not think the ducts are large enough.
2. I think that it is too heavy. Currently ~13oz with all electronics + battery (pre coating)
3. I feel as if just ailerons will not do for only control surfaces (no extra space to add more or put on drag rudders)
4. Wings do not seem large enough.
Without further adieu!
Old Jan 19, 2014, 07:46 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
looks great so far 13oz isnt heavy for a 50mm. whats the wing area?
most mine are 16-17 oz and can top 85mph with a don's wicked 4s setup.
please clean up that spagetti from in front of the unit.
D_FAST is offline Find More Posts by D_FAST
Latest blog entry: Dassualt Alpha Jet
Old Jan 20, 2014, 12:48 PM
Joined May 2008
Yeah I had to do all the wiring into the plane to begin and it will be cleaned up. Not close to working on the interior, trying to get the exterior and wing/elevons in and working and glassing then I will go to the wire routing and cleaning up the inside.
I have learned trying to make this plane with this size is very hard with the ducting taking up most of the room in the main fuselage and wiring, battery, rx, etc. also taking up a lot of room. Its what I get for making it fit within a $tree foam board size 20x30in.
Old Apr 25, 2014, 09:50 PM
Mike Brinker
tr6world's Avatar
SouthEast Michigan
Joined May 2008
Any progress Jeff?
Discussion X-47b(ucas) samwei1950 Foamies (Scratchbuilt) 32 Apr 15, 2014 11:16 PM
Discussion X-47B Cat Launch & USS TRUMAN loading AndyKunz Dock Talk 7 Dec 04, 2012 09:58 PM
Discussion US Navy X-47B UCAS First Cat Launch Park_Flyer Life, The Universe, and Politics 7 Dec 01, 2012 06:52 PM
Discussion X 47b stoneenforcer Electric Ducted Fan Jet Talk 0 Jun 14, 2012 03:31 PM
Discussion X-47b plans available RCvertt Flying Wings 19 Apr 25, 2011 12:49 AM
