Old Aug 24, 2013, 03:18 AM
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
@prodriverex
AUW of the setup like in the last video is about 8kg
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Aug 24, 2013, 06:35 AM
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
That's v light for 16 motors, ESCs and payloads..
prodriverex is offline Find More Posts by prodriverex
Latest blog entry: Gimball Drone
Old Aug 24, 2013, 11:59 AM
EndOfDays's Avatar
Joined Jan 2010
Sorry I forgot, the flighttime is 24min in this setup (with 4x4S9000 foxtech). With 4x4S11000maxamps.com it is 30min.
best regards
Ferdinand
Old Aug 26, 2013, 01:14 PM
United States, CA, Hayward
Joined Apr 2006
very nice ferdinand! i did not think a wk-m could flip! thanks for sharing!
why didn't you go 6s?
chris24g is online now Find More Posts by chris24g
Old Aug 26, 2013, 01:47 PM
EndOfDays's Avatar
Joined Jan 2010
I only have 4S batteries (removed all 6S), another reason is, that I can power the VTX/Alexmos directly.
Here another video:
2013-08-24: X16 practice (5 min 41 sec)
best regards
Ferdinand
Old Aug 26, 2013, 03:20 PM
United States, OR, Portland
Joined Apr 2011
Amazing!!!
fallingdown is offline Find More Posts by fallingdown
Old Oct 10, 2013, 05:49 PM
KillerOfDolts's Avatar
Waterville, Maine
Joined Oct 2006
EndOfDays....You are AWSOME! Love what you've done and are doing.
KillerOfDolts is online now Find More Posts by KillerOfDolts
Old Apr 11, 2014, 12:55 AM
Joined Apr 2014
Great job on the X16 EOD!
Mikerodrig27 is offline Find More Posts by Mikerodrig27
Old Jun 05, 2014, 01:04 PM
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Originally Posted by EndOfDays View Post
The less load you have per propeller, the better it´s efficiency becomes. This is even true for coax, since you save more load/propeller, than you might loose in efficiency due to the coax. In addition you have more reserves, and more redundancy.
The "total fuel" will be 4x4S8000 Zippy=3kg (=28000-30000mAh usable) here I have 25min. With 4x4S11000 maxamps=3,6kg (=40000mAh usable) I should be able to beat the 30min.
I already had
19min with 4x4S6000 nano-tech=2,5kg(=21000mAh used) and
16min with 4x4S5800 ep-car-lipo=2,0kg(=18000mAh used)
The more I am playing around with calculations, the more I find these formula valid:
http://www.flugst0ff.de/copterflugzeiten-berechnen/
My efficiency coefficient for this copter is 0,37 (just for a comparison the quad I used for the 65min flight hat 0,42)
If somebody is interested, I have attached an xls-sheet where you can enter your own data and get a flight-time estimation. The "efficiency" value is something to be determined for a given prop/motor/esc-combo, and is (hopefully) in the range of (0,3-0,5 the higher the better the efficiency) the "capacity" is the mAh you recharged (not what is printed on the lipo). Please be aware, that this is not my formula, it is the formula of the page cited above, I just put it into an xls-sheet.
best regards
Ferdinand
Sorry to bring back such an old thread!
Could you explain what "capa Netto Kapa" means under the E column. Just a little confused how that works itself into all the quations
v00d0o is offline Find More Posts by v00d0o
Old Jun 05, 2014, 03:50 PM
EndOfDays's Avatar
Joined Jan 2010
it just means what mAh you really can get out of your battery, not what is on the sticker.
best regards
Ferdinand
Old Aug 08, 2014, 10:00 AM
EndOfDays's Avatar
Joined Jan 2010
The X16 got a facelift ...
Took off the motors:
disassembled the frame:
new frame with direct connections on the booms:
reinforced with CFK rovings and finally added cfk reinforced aramid-wavers:
Motors mounted again:
-250gr in weight, and now overall better stiffness especially the torsion.
weight is now 3400gr with landing-legs (here the weight could still be optimized).
Testflight was already successful, video will follow.
best regards
Ferdinand
Old Aug 08, 2014, 10:22 AM
Joined Apr 2007
Ferdinand, you are insane!
I really like your experiemnts, doing stuff that I have never seen anybody else do.
What motors are you using?
tritan is offline Find More Posts by tritan
Old Aug 08, 2014, 10:55 AM
EndOfDays's Avatar
Joined Jan 2010
Still the same NX-4006-530KV, as before.
best regards
Ferdinand
Old Aug 08, 2014, 11:05 AM
Joined Apr 2007
Ok,
you are using them a lot, on many multis, have you ever had any problems with them?
I mean, your multis are not exactly cheap but your still use such rather low cost motors.
Old Aug 08, 2014, 11:15 PM
TruckBasher's Avatar
Joined Oct 2011
Nice Ferdinand.
Yes his mutli are not really cheap specially the 2-stage Multi and that was using same motor if not mistaken
TruckBasher is offline Find More Posts by TruckBasher
Help! i'm looking for a tiny video cam for an r/c jet iflyrc1012 Aerial Photography 1 Jun 24, 2012 05:00 PM
Question Suggestions for an old timer build using an FS20 or 26. mrcosmo Vintage & Old-Timer Designs 31 Apr 14, 2012 08:45 AM
Discussion Anyone tried an 808 cam on an Ember? Rob_P Micro Ready-to-Fly 5 Mar 23, 2012 01:33 PM
Discussion Building Heavy lifter Octo and need wisdom on motor choice 4242Film Multirotor Talk 7 Jul 27, 2010 05:05 PM
