Old Sep 29, 2012, 07:42 PM
AMA #903699
Tony_Fletcher's Avatar
USA, VA, Alexandria
Joined Mar 2008
HELP! Trying to identify this part
I have located this style part in the Dubro catalog, but's it is much larger. It connects two ailerons on a biplane wing, approx. 40" wingspan. Any ideas?
Tony_Fletcher is offline Find More Posts by Tony_Fletcher
Old Sep 29, 2012, 08:59 PM
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
Looks like a cut up torque rod to me. I havent owned a bipe so some sone more knowledgable would probably know better
scrub monkey is offline Find More Posts by scrub monkey
Old Sep 30, 2012, 04:10 AM
Bradford West Yorkshire, UK
Joined Apr 2010
Aileron torque rod connecter.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Sep 30, 2012, 05:33 AM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Those parts were available in many kits,and at one time were offered by Goldberg and Dubro.
They had a variety of uses and were called aileron connectors most often..
They came in different sizes,mostly for 2-56 and 4-40 threads
epoxyearl is online now Find More Posts by epoxyearl
Old Sep 30, 2012, 08:48 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There must be quite a few ways of linking ailerons on a bipe, but finding a matching 'thingamajig' may not be so easy.
Here's a very simple, (crude ?) way to link ailerons on a bipe -
Simple biplane aileron linkage (0 min 34 sec)
eflightray is offline Find More Posts by eflightray
Old Oct 01, 2012, 02:56 AM
United States, TX, Leander
Joined Sep 2003
I've used smaller dubro or gp control horns trimed down to the lowest hole, top of the bottom aileron, and bottom of the top aileron.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Oct 04, 2012, 03:08 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
That piece needs to be rotated vertical with the hole upward on the bottom wing and downward on the upper wing connected by rod with clevises in each end. Those pieces were used for single servo middle wing aileron torque rod connectors as stated.
Thermalin is offline Find More Posts by Thermalin
Old Oct 05, 2012, 12:48 PM
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
SIG aileron connectors come in 2-56 and 4-40
http://www.sigmfg.com/cgi-bin/dpsmar...n_20Linkage_01
Du-Bro has some larger 6-32 and 8-32 horns in the HD pull pull control horn kits
6-32 kit
http://shop.dubro.com/products/produ...6.0.0.0?pp=12&
8-32 kit
sscherin is offline Find More Posts by sscherin
Old Oct 08, 2012, 05:27 PM
AMA #903699
USA, VA, Alexandria
Joined Mar 2008
Perfect! Thanks for the link. I ordered some today.
Old Oct 13, 2012, 09:35 AM
AMA #903699
USA, VA, Alexandria
Joined Mar 2008
Thanks for the heads-up on the SIG part. I think they'll be perfect! Thank you!
Old Oct 14, 2012, 03:02 PM
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
A little late, but another option is...
Sig Nylon Aileron Interconnect Horn, cat. no. sigsh755, priced at $5.
They came with some of the older Sig biplane kits. What you have already should work well.
Balsabird is online now Find More Posts by Balsabird
Help! Need help to identify this helicopter for parts chrisnasah Micro Helis 7 Aug 17, 2012 12:54 PM
Discussion How about this Mosfet Driver chip.... Please help me identify this one gta18 DIY Electronics 12 Aug 05, 2012 04:46 PM
Help! Trying to identify this gimbal KiTCyclic Multirotor Talk 3 Jul 27, 2012 09:41 AM
Help! PLease identify this part Fingerlessfred Large Electric Helis 0 Jun 20, 2012 09:58 AM
Discussion Identify this part for me please. SARCFAN Racing Boats - Electric 6 May 09, 2012 09:59 PM
