Old Sep 01, 2010, 03:33 PM
UK,Suffolk Newmarket
Joined Aug 2010
Sail Winches
Hi all You Voyager SailBoat Skippers. I'm a new boy in this R/C \sailing and am just about to commence building my Thunder Tiger Voyager kit. But it would appear that it is left to the builder as to what sail winch he builds in to his boatas one was not included with my Futaba T2ER Radio. What winch would you advise me to get.
cabinboy is offline Find More Posts by cabinboy
Old Sep 01, 2010, 04:58 PM
larrykin's Avatar
Sydney, Australia
Joined May 2008
I'd use a Hitec Sail Arm Servo and a Hitec 311 Rudder Servo. Below is how I rigged my USOM. With the Hitec arm supplied. Looks complex but is worth the effort for ease of adjustment.
Alternately make your own arm as a "double purchase" setup. I think double purchase work better as they are more balanced but you need to calculate the arm lengths to get correct sail swing. Jib and boom have different travel to get both at 90 degrees on downwind run.
Below is a "double purchase" arm.
larrykin is offline Find More Posts by larrykin
Old Sep 02, 2010, 05:14 AM
Blackpool, Lancs
Joined Feb 2006
Its designed for a "standard" size servo, but these are not really man enough for anything but the slightest breeze. I shopped around and got a high torque version, same external dimensions, lots more pull. The instructions for the Victoria intend a single ended arm. I had to make a new arm, about 5 minutes attacking a piece of scrap plywood.
mfr02 is offline Find More Posts by mfr02
Old Sep 10, 2010, 09:59 AM
Joined Aug 2010
Greetings to Larrykin & mfrO2. Thanks for your reply to my query about winches. Apologies for this late reply but have been away. There's a helluva lot more to this sailboat lark than meets the eye innit.
Old Sep 10, 2010, 11:36 PM
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Larrykin, the arm, and boat, looks very nice. Do you find the 'bent around' shape helps with extra torque at the end of the travel, and less snags? I've seen designs like this many times, but have never done it myself. I am building several big (54") boats and an arm like that would fit very nicely.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Sep 11, 2010, 10:53 PM
tbarjohn's Avatar
aurora, il.
Joined Aug 2009
Dave, here's one I just put in a Santa Barbara 70" long, the offset on the ends is so the blocks can rotate as the arm swigs from end to end.
John R.
tbarjohn is offline Find More Posts by tbarjohn
Discussion Winches for sailboats - actual miniatures of Harken winches and more Boomer1 Sailboats 33 Feb 17, 2012 11:55 AM
Discussion Sail Control Systems winches servos etc. DaveMainzone Sailboats 8 Nov 03, 2008 05:03 AM
