Old Feb 07, 2010, 07:28 PM
Lots foam, so little time
Depron Dave's Avatar
northridge California
Stryker control loss at speed????
OK I built a stryker from spare parts I purchased from Horizon Hobby.
I didn't want the stock paint job and I put in my own electronics.
With my latest setup every thing works fine except when I am firewalled straight and level the controls are ineffective…
It’s not radio loss because when I slow down I have control again.
And the control comes back proportionally with airspeed reduction.
I found this out by pointing it straight up, full throttle and it does stay in control.
Two things I suspect, elevon flex, but there stiff??
Or servo stall
Would love for another opinion, or confirmation
Here is the setup
DX7 for control
2 HS 56 servos
Wrong they are hs82
power....
Of course it's HK stuff
Turnigy 2836 Brushless EDF Motor 3200kv
70 amp speed control (a little over kill)
3amp turnigy BEC
4 cell 35c 2200 mah battery
APC 5 x5 prop.
Runs exceptionally cool…and fast
Dave
Depron Dave is offline Find More Posts by Depron Dave
Old Feb 08, 2010, 06:29 AM
United Kingdom, England, Redcar
Joined Jan 2006
Id vote for servo stall
scousethief is offline Find More Posts by scousethief
Old Feb 08, 2010, 11:37 AM
Meditative flight
ibcellist's Avatar
Virginia
Joined Jun 2009
Agreed. Get servos with a higher torque and you'll probably be fine.
ibcellist is offline Find More Posts by ibcellist
Old Feb 12, 2010, 07:32 PM
Nope they are HS 82
Nope they are HS 82 and I was below 100mph.
now my eye goes toward the BEC, It is a 3 amp unit.
Contest 2010 Flat Foam Speed Challenge: Top speed is JIMBAKER at 91.0 mph The Don Foamies (Scratchbuilt) 986 Jan 23, 2011 11:23 AM
Help! Loss of throttle control....1%stick acts like 100% TN_heli_pilot Mini Helis 3 Jan 25, 2010 06:12 PM
Discussion Possible causes for sudden loss of control... cjmdjm Electric Plane Talk 8 Jan 13, 2010 06:16 PM
Speed control for Stryker F-27 johnnyrotor Power Systems 1 Mar 30, 2005 11:22 PM
loss of tail control at high throttle rcworm Micro Helis 10 Jan 16, 2005 10:47 PM
