Old Mar 24, 2003, 02:03 AM
living in Japan member
Belgium (Europe)
Joined Oct 2002
slowstick little help needed
I flew my picostick into oblivion yesterday and had so much fun I decided I need a slowstick
I want to know what is needed for the following mods
replacement of aluminium dihedral by brass piece of tube: what kind of tube is needed? diameter (if possible in metric)
what kind of carbon rods do I to avoid the sloppy control by the standard push rods?
and lastly can someone point me to a good slowstick mod thread because I ve been searching/reading more than 6 hours yesterday to find the right info.
many many thanks
anatak
anatak is offline Find More Posts by anatak
Old Mar 24, 2003, 06:55 AM
no place like cloudbase
freeflight's Avatar
Columbus, Ohio
Joined Aug 2002
ss mods
Anatak,
Not sure about exact diameter of the tube. I used brass and some little sloppy fit carbon fiber rods and epoxy. Put fiberglass rod inside of brass tube and bend gently to correct dihederal. Pull rod out after. The rod helps keep the tube from kinking.
You can use the carbon fiber rod from www.airdyn.com in the 1.25 mm size for pushrods.
Not sure of a link for ya though.
Leigh
freeflight is offline Find More Posts by freeflight
A little help needed Old 8140 Scale Boats 2 Nov 23, 2005 01:49 PM
Rave Mini DragonFly Modified - Newbies Review and a little Help needed! RMEFlyer Micro Helis 11 Jan 13, 2005 01:48 PM
Little help needed with joke. Al Dente Life, The Universe, and Politics 16 May 04, 2004 12:06 AM
