Old Aug 21, 2005, 05:53 PM
idk
ripper69's Avatar
Inver Grove Heights ,MN
Joined Jul 2004
Bn2 EDF
I need a cheap way to get more power. I'm not sure if I want brushless because of haveing to get 2 speed controls. Is there a way to get some bigger motors in the stock ips fans? Or should I just rip them off buy some cowlings and put some johnson 250's in it?
ripper69 is offline Find More Posts by ripper69
Old Aug 22, 2005, 04:18 PM
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
depends what edf-50s you have. You can always upgrade to the 5 blade units or go for the uprated motors that will handle more cells(read 3 cell lipo)
Robbie d is offline Find More Posts by Robbie d
Old Aug 22, 2005, 05:03 PM
idk
ripper69's Avatar
Joined Jul 2004
Can i just get the 5 blade props and stick them in there?
Old Aug 22, 2005, 09:01 PM
shschon's Avatar
United States, CA, SF
Joined Aug 2004
It is odd for people asking for more power for BN2 Jet. The stock motors are already overpowering the little jet. If you feel under power check the following items first:
(1) Is your battery powerful enough? On full throttle you should get 8~9 Amp.
(2) Is your ESC good enough? It needs to handle 8~10 Amp continuous.
(3) Is your electrical connectors good? The stock GWS/BEC/JST red connector is only good for a few Amps. At the 8~10Amp level for the stock motor to develop full power, the small connectors simply robs away a lot of power and turns them into heat that often melt the connector.
Really, many cases it is NOT the motor, it is small components in your power system that is underperforming.
Moving to 5 blade using the same motor only give you 1~2 gram more thrust but almost 2 Amps increase in current, not good.
Moving to the BH high voltage motor and 5 blade is a way to reduce Amp draw, but power is the same or slightly less.
shschon is offline Find More Posts by shschon
Old Aug 22, 2005, 09:29 PM
idk
ripper69's Avatar
Joined Jul 2004
Hum, well my I'm not new to this. All of my stuff it far beyond what this calls for. The 280 prop version was way faster.
BN2 EDF maiden today ipjodan GWS (Grand Wing Servo) 5 Oct 25, 2005 11:42 AM
Bn2 EDF-EDP BEST PICURES WITH SPECIFICATIONS agapornis GWS (Grand Wing Servo) 1 Feb 20, 2005 01:05 AM
GWS BN2 - EDF or Prop Lewist Electric Ducted Fan Jet Talk 21 Dec 16, 2004 04:58 PM
BN2 EDF Dilemma Buzzard21 GWS (Grand Wing Servo) 5 Sep 02, 2004 02:46 AM
Wtb Bn2 Edf termite Aircraft - Electric - Airplanes (FS/W) 0 Sep 19, 2003 05:20 PM
