Old Apr 21, 2014, 06:54 AM
Manudepron's Avatar
Belgium, Walloon Region, Namur
Joined Apr 2010
Mini-Review
Su 37 Terminator from Miniprop (with video post 9)
I bought this EPP kit from Staufenbiel in Germany. 40Ä. The kit contains EPP pieces and some hardware.
You need to buy motor, esc, servo's, receiver and battery.
This will be my first vector jet.
Pieces are well cut and fits nicely.
Building as usual from EPP and inserted carbon strips and rods glued with Cyano.
I Used big square hardwood blocs as templates and weight to ensure flatness.
I will use a Turnigy D2822/14 Brushless Outrunner 1450kv weighting around 38grs, a 25A esc and 4 pces HXT 900 9 grs servos I have in stock. Battery 3s 800 mah.
Manudepron is offline Find More Posts by Manudepron
Old Apr 22, 2014, 01:19 AM
Manudepron's Avatar
Joined Apr 2010
Ready to fly
It's finished and ready to fly at 379 grs inclusive a 3 s 800 mah battery.
Seems me possible to save 5 grs on receiver, 10 grs on esc and wiring.. not more.
6 grs servo's seems me too weak (gears mainly)
I did yesterday a quick promising first fly before rain: very powerfull, elevator hyper reactive, very sensitive to adverse effect of the rotating prop. I maidened with a 8 x 4.3 and will next fly prop down to 7 x 4 (as on the pictures enclosed that were made after maiden at home. I will install a conter weight at the tip of one wing.
Consumption on the 8 x 4.3 was too high at 17 A. My test with the 7 x 4 drops consumption at 12 A thus perfect for this motor.
Old Apr 22, 2014, 04:06 PM
Manudepron's Avatar
Joined Apr 2010
Refuses to turn to right... Ideas?
Made a second flight with the 7/4 prop: power is OK, turns and banks very well to the left and nearly not to the right! Counter torque effect! It's not my first pusher prop jet, but seems me odd at that level of counter torque with such a small prop! Any idea?
Old Apr 23, 2014, 09:06 AM
United States, VA, Herndon
Joined May 2007
If you get some altitude and cut the throttle are you able to turn right? Did you have to add a lot of trim to keep it flying straight and level?
wilmracer is online now Find More Posts by wilmracer
Old Apr 23, 2014, 01:33 PM
Manudepron's Avatar
Joined Apr 2010
Your idea is great! But it's solved!
I woke up this morning with one solution: adjust side trust to the right and add a small 6 grs weight on the right wing tip! I did a quick test and i's fantastic! My original mistake was a motor mount slightly glued with a left side trust, maybe one degree but in addition with the torque was a big hint! Flies now great, I did 2 packs with great pleasure! Thanks for sharing your idea as it was a good way to try!
Old Apr 23, 2014, 01:44 PM
Joined May 2007
Glad to hear you got it worked out!
Old Apr 23, 2014, 01:47 PM
Manudepron's Avatar
Joined Apr 2010
Thanks! I will post a video as soon as possible!
Old Apr 30, 2014, 10:59 AM
Joined Apr 2014
that right,I did 2 packs with great pleasure! Thanks for sharing your idea as it was a good way to try!
bercasebbco is offline Find More Posts by bercasebbco
Old May 01, 2014, 04:00 PM
Manudepron's Avatar
Joined Apr 2010
Video
SU 27 Miniprop (1 min 14 sec)
To show you this plane potential. My first "self video recording" thanks to a camera attached on my cap. This plane needs some speed to be on tracks
Old May 06, 2014, 01:46 AM
Manudepron's Avatar
Joined Apr 2010
See this all on my blog
All the informations condensed here: this plane is a real pleasure and managing cobra's is a kind of play I enjoy. I do it lower and lower until... we will see
http://www.rcgroups.com/forums/member.php?u=310184
Enjoy
Discussion What to build:130% Jetset44 SU-37 or 60" A-10? addictedtoplanes Pusher Prop Jet Models 7 Dec 04, 2013 07:10 PM
Discussion Nice SU-37 Composite from HK Hover or die Electric Ducted Fan Jet Talk 5 Apr 03, 2012 08:59 AM
Gallery Su-37 from Steve Shumate Guglito Pusher Prop Jet Models 3 Jun 06, 2007 06:52 PM
Question Any EDF Flanker coming from GWS? (Su-27, 30... 37) Tanguy&Laverdure GWS (Grand Wing Servo) 10 Aug 15, 2005 09:02 PM
SU 27 & 37 from Northeast Sailplane Products CarreraGTSCS Electric Ducted Fan Jet Talk 8 Feb 11, 2004 11:53 AM
