Old Nov 19, 2012, 11:25 PM
If it flies I like it.
HotdogX's Avatar
Madison, AL
Joined Sep 2004
Jepe Pyranha Exhaust Size?
Question for anyone who has built and flown a Jepe Pyranha. I'm building a Jepe Pyranha from the glass fuse and wood wing/tail kit. The cut off foam cup that is used for the tail cone gives a tail pipe diameter of 47mm. The photo instructions don't show or state what the tail pipe exhaust diameter should be. 47mm seems a bit small for a 70mm fan (WeMoTec 480), but since the cup was already cut off in the kit am I safe to assume the 47mm diameter is correct? I'm using a Mega 16/15/3 motor on 4S LiPo.
HotdogX is offline Find More Posts by HotdogX
Old Nov 19, 2012, 11:45 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Here's a 70mm shroud ID, with a motor tube OD of 31mm . Might help.
Exhaust Diameter (single outlet)
100% FSA 62.76145314
95% FSA 61.17229765
90% FSA 59.54074235
85% FSA 57.86320074
80% FSA 56.13555023
75% FSA 54.3530128
70% FSA 52.50999905
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 19, 2012, 11:47 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
52-54mm
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 20, 2012, 07:15 AM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
That is the correct diameter for the minifan on 4s. I would love to find a virgin jepe kit. Kevin Saunders added ailerons to his and it rolls much better.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Nov 20, 2012, 07:22 AM
HotdogX's Avatar
Madison, AL
Joined Sep 2004
Guess I'll split the difference and go with 53mm.
I already have the wing built and shaped, so not sure how I'd put ailerons in at this point. It's a very thin wing. One could use two separate servos, but it would be tricky to run the leads now that the ribs are already installed. Guess I'll just go with the tailerons for now.
Thanks for the help guys!
Al
Old Nov 20, 2012, 07:47 AM
High Dynamic Thrust
Joined Feb 2007
ive got a glass wing. not used. just pm me if you want it.
My Jepe Pyranha devmonkey Electric Ducted Fan Jet Talk 11 May 28, 2005 09:10 PM
Rave JePe Pyranha micro jet fitzman Electric Ducted Fan Jet Talk 25 Aug 17, 2004 03:23 PM
How many Jepe Pyranha's out there? Jim Walker Electric Ducted Fan Jet Talk 1 Aug 08, 2003 05:35 PM
Jepe Pyranha Sluf7 Electric Ducted Fan Jet Talk 6 Jul 28, 2003 12:32 AM
Pyranha MK-1 jepe christopher2 Electric Ducted Fan Jet Talk 4 Apr 08, 2003 01:10 PM
