Old Jun 03, 2012, 12:19 PM
Falkland Islands
Joined Dec 2010
Spot welding...for up and coming turbine build
Hi, any ideas on a homebuilt Spot Welders? about to embark on a gas turbine build and need to build the combustor unit etc.
I could afford to buy a TIG unit, but not sure on the availability of gas for this. MIG is possible, got a home type unit but again gas is a pain to come by...I only use this unit with flux cored wire.
The SS sheet is only 0.5 mm or so...with 0.8 for some sections.
I have seen homebuilt spot units on Ytube, which are interesting...any basic plans on how to wire these up?
robwilkinson is offline Find More Posts by robwilkinson
Old Jun 06, 2012, 06:40 AM
Closed Account
Joined Jun 2002
Spot Welder controller
I make a controller that I use with a Harbor Freight, Spot Welder. The controller controls Power from 1% to 100%, and time from .1 sec to 4 sec, in .1 sec incerments. I have also modified the electrodes on the welder. I have a couple extra circuts boards I can populate with parts and make some controllers to sell.
LJE4357 is offline Find More Posts by LJE4357
Old Jun 06, 2012, 03:01 PM
Falkland Islands
Joined Dec 2010
Hi, thanks for the reply and details. I need a 240-250 volt system...where I live has the UK voltage...you are on 110v in the USA...right?
Old Jun 06, 2012, 05:06 PM
Closed Account
Joined Jun 2002
Not a problem, The unit I make ( the one in the pic) works on 110/220, 50/60 hz. but it does have to be single phase. If you need 3 phase I can do that to.
Larry
Old Nov 20, 2012, 01:33 AM
Joined Nov 2012
It is very easy to do spot welding or projection welding. Many type of welding machines are available in the market but our company's machines are one of the best in welding and you can weld any type of metal easily.
__________________
projection welding
robertval is offline Find More Posts by robertval
Old Nov 20, 2012, 01:40 AM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
i spotwelded the bolt carrier guides on an AK-47 reciever using a spot welder from Harbour Freight.. it works
KCinNC is online now Find More Posts by KCinNC
Help! How can this be fixed..weld, JB Weld...etc? ABADGTP Fuel Plane Talk 20 Nov 06, 2011 08:07 PM
Discussion The worst building ideas you have come up with SBS_Pilot The Builders Workshop 26 Oct 06, 2011 03:33 PM
Joke got a new turbin for my jet GOJIRADOR Humor 4 Jun 28, 2006 08:51 PM
Spot weld upper limits? fill Batteries and Chargers 6 Aug 04, 2005 11:24 AM
GP3300 with Spot weld tabs, don't do it! rcjetpilot Batteries and Chargers 7 May 12, 2004 10:22 PM
