Old Apr 22, 2011, 10:41 AM
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Help!
F-18 Exhaust Diameter to small?
Hello Everyone
I just needed to make a quick new thread.
My friend bought a foamie edf F-18 Airframe only kit which he rebuild and glassed.
Now inside is a 127mm Ramtec Fan and housing with a scorpion outrunner motor.
A Castle Creations 160HV Amp esc as well as 8x4S 4000 Nano Tech Batteries to create a 12s /8000mah Battery Setup, I think.
His exhaust Diameter of the twin exhaust nozzles of the F-18 is 6.5cm or 65mm in diameter wide.
The Size of the F-18 is like a good 1.7meters long with a 1.2m wingspan.
Total Weight with these batteries is 7.4 kg. Thrust is 6.5-6.7kg.
Now...the sound is very loud and when holding the jet to make a thrust test of the ground , you can't let it go otherwise it would hit the ground.
My thought was that the 65mm diameter of the twin exhaust's is too small.
We haven't got a amp reading on it . But he want's to maiden his Jet tomorrow.
Any thoughts or ideas?
The plane is from hayoe I think.
Regards
NS.
neversommer is offline Find More Posts by neversommer
Old Apr 22, 2011, 12:35 PM
Effumall
kelberts's Avatar
Joined Nov 2005
Outlet needs to be no smaller than about 75% of FSA. In this case, you'd need about 80-90mm, so yes that outlet is way too small. (Assuming the two outlets add up to 63mm). You won't get a lot of thrust from this situation, and certainly not enough static thrust at takeoff to get airborne. Just for grins, what's the inlet area? I bet that's too small as well. Sounds like the airframe is designed for a smaller fan.
kelberts is offline Find More Posts by kelberts
Old Apr 22, 2011, 12:43 PM
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
You need a bifurcated (split) airflow exhaust duct. Each side will need to be 68.75mm in diameter. This will give about 85% FSA when you add the two areas together, and should do well. You are a little under with the 65mm openings, but it may be acceptable. Doug
Doug Bateman is offline Find More Posts by Doug Bateman
Sold Texas Deals - BTE Wing, F-18's, F-16, LX Twin A-10 Roswalt Non R/C Items (FS/W) 7 Jun 19, 2012 06:25 PM
Found small props 5, 6, 7 inch diameter Doubledog Aircraft - General - Miscellaneous (FS/W) 0 Mar 20, 2011 03:33 AM
Sold OS .18 tz motor for sale with revo exhaust ronmad02 Cars - Trucks and Parts (FS/W) 0 Mar 07, 2011 01:09 PM
Build Log 1/13 scale Midi F-18 with bifurcated exhaust duct and retracts eatond Electric Ducted Fan Jet Talk 39 Dec 13, 2009 07:54 PM
Video Flight Test- EDF Variable Diameter Exhaust Nozzle F-16 tailslide5_0 Electric Plane Talk 27 Feb 11, 2009 08:17 AM
