Old Aug 08, 2008, 11:36 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Build Log
Sparky is back with a B-58 hustler (66 inch long @ 4 pounds)
I would post this on the EDF page but Iíve been told that foam EDF models are taboo there for some reason.
The model has about 40 minuets in the air to date. . . .it's a done deal.
The design has been turned in as a construction article to Flying Models Magazine.
Iíll let you know when it comes out as soon as I know.
All will be revealed in time so stay tuned.
Plans will be available through the magazine. When the article is released.
The plastic parts I made for the B-58 will become available as well as a laser cut wood set too.
Here is a thread index so you can go straight to the section you want.
page post # section
1 ............. 4............. wing frame.
1 ............. 4..............servo mount
2 ............24............wing sheeting
3 ............ 40............Elevons
3............ .45............fuselage
5 ..............65 ..........fairing
5 ........ ... 68.......... fin
6 ............. 87 .......... fin attach
6 ............. 89............hatch
8 .............106 ...........pylons
8...............108............ducts
8......... ....110.......... nacelles
8..............112 ........... ESC
9 .......... ...126 ......... flight test
9 ........ .....146 .......... flight photos
sparks is offline Find More Posts by sparks
Old Aug 08, 2008, 11:39 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Why?
The B-58 hustler has been on my design list for a few years now.
The desire popped up again when I watched Tom B. fly his fly-fly Mirage from EJF at BEST last year. Nice hand launch Richard.. . . . . .
Then came the L-39 , what a cool little power unit. This got the wheels turning again and I discussed it a little with Dave G.
A few weeks later he came to the shop with a cheaper motor / fan unit from RC hot deals
É≥55Ā~H33 Outrunner Brushless Motor Ducted Fan W/ Motor 2409H-7T.
We did a bench run and that was all it took.
With a three view on the lap top I laid out the model and started construction.
Old Aug 08, 2008, 11:45 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
my goal
The goal was to build a large, light weight B-58 that can operate off of grass and not empty a guys wallet doing it.
Any one can design a money hungry pig, we see it every day a new ARF arrives. If I left something off the model you think it should have had, it was to save weight or money.
Iíve designed a Hustler with light wing loading; what you add from there is up to you.
Old Aug 08, 2008, 11:49 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
getting started
I love to build wings and itís a good thing too because this design is just a flying wing with a fuselage along for the ride. . .A good place to start for visual progress and inspiration.
I took a sheet of 3mm Depron and cut diagonally to fit the plans and bonded a strip down the center as a splice. Wile it cured I transferred the rib patterns to 6mm depron and 1/8 balsa.
IĎve caught flack before for drawing plans with only one wing and chances are I will again but you donít build this wing over the plans. You build it over the bottom sheeting so the plans are only for reference. The slots in spars set the rib locations for you, all you do is be sure they are straight and against the bottom sheeting.
I used tapered stock to force the bottom sheeting against the rib leading edge. (after the weight is applied) This only does part of the job though, narrow strips of scrap depron shoved between the sheeting and tapered stock does any adjustments.
I prefer polyurethane glue for this assembly method.
Plenty of time for adjustments and when it foams up any small gaps are filled.
The bottle said we have 8 hours drying time . . .I give a whole day.
Start collecting small weights now because thatís all I used for clamp pressure.
Old Aug 08, 2008, 11:51 AM
Coop is offline
Find More Posts by Coop
Lawton/Fort Sill, OK
Joined Sep 2002
I am very interested in the build thread Sparks or will there be one?
Coop is offline Find More Posts by Coop
Old Aug 08, 2008, 11:52 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
To make the flippers match the wing I build them as part of the wing and cut them free later. I know, know; elevons.
The hinge line gets a coat of Vaseline to prevent them from bonding and pushing a pin through the wing skin will allow you to make accurate marks for cutting it free later.
For the other wing panel I simply pushed down the spar flat against the sheeting and placed blocks under the completed side while I repeated the frame steps.
Old Aug 08, 2008, 11:58 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Building the servo mount ďboxĒ is done with 6mm foam sheeting.
Some quick measurements and marks locate the hole the servo will be mounted through in the lower skin The servo is held in place with an interference fit and a dab of silicone for safety.
Quick tip . run your wiring now.
I had to move them three times not knowing where the components would need to be and it was not easy. More on this later.
On the plans I made it very clear and straight forward. Install them now, they will be waiting there for you when you need them.
Thats enough for now, see you
Monday.
Old Aug 08, 2008, 09:42 PM
Brian Allen is offline
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Keith
What a great design!! The B-58 is one of those planes that just cries out to be modeled but is rarely done. Will be watching this with interest!!
Brian Allen
Veni Vidi Volavi
I came Isaw I flew
Brian Allen is offline Find More Posts by Brian Allen
Old Aug 08, 2008, 10:20 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Hey, I knew you were up to something Wondered if it was this or the next MD80.
Looks like it is coming along nicely. Since you're this far along I guess we haven't kept you busy enough
charlie
portablevcb is offline Find More Posts by portablevcb
Old Aug 08, 2008, 10:49 PM
Synwpn is offline
Find More Posts by Synwpn
go fly! no crashes!
Synwpn's Avatar
Honolulu, HI
Joined Jun 2003
very cool! i'm a watching or lurking. heh.
Synwpn is offline Find More Posts by Synwpn
Old Aug 08, 2008, 11:31 PM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
You REALLY need to go to Galveston, and see the B-58 at the Lone Star Museum of Flight!!!! OH! Don't get too close to the Grumman F3F there. Its contagious!
challenger_i is offline Find More Posts by challenger_i
Old Aug 09, 2008, 12:10 AM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
I've long thought the Hustler was a really mean looking flying machine! But how are you gonna build scale-size engine nacelles and have adequate performance?
BTW, I visited with Hausen Liang, owner of RC Hot Deals today. It's a good thing you got those fans when you did, since he says NOTHING is getting out of the factories anywhere near Beijing until the olympics are over, and that's where those fans are made.
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Aug 09, 2008, 09:25 AM
expat flyer is offline
Find More Posts by expat flyer
Toulouse
Joined Jan 2007
Wise to allow reaction time with polyutethane glue. It foams and sets by absorbing moisture from the wood in carpentry applications. With dry modelling wood and foam the only moisture is from the air. A very light watering could speed things up, e.g. perfume bottle.
Jerry
expat flyer is offline Find More Posts by expat flyer
Old Aug 09, 2008, 10:23 AM
scratchnhover is offline
Find More Posts by scratchnhover
Fly2Build.com
scratchnhover's Avatar
Redding,California
Joined Dec 2003
Keith: Signing on for this one. It is a sweet looking subject and I can't wait to see your plastic magic at work again.
scratchnhover is offline Find More Posts by scratchnhover
Old Aug 09, 2008, 01:25 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Charlie, I do tend to drop off the "zone radar" from time to time.
With several projects running all the time it really hard to get things out in a timely fashion.
Most of my computer time has been taken up assembling information for my up coming web site, The next construction article, three new pilot figures, and . Bla, Bla, Bla.
Challenger. the B-58 is "in the can" as Pat T. putt's it. but I did get a chance to climb all over one while I was in the Air force. The base commander ran it off the end of the runway and it was too expensive to move it so they salvaged the husk and left it there. It has since been removed. I checked it with Goggle earth.
Geoffinpdx . . . . . . it's all about wing loading. Like I said, any one can design a pig.
Also I never said it would be fast. . . . . . when the model is in the air at full power it looks like what I feel is scale speed. (In our world that's about 40 to 50 MPH) Keep in mind since I have never seen a B-58 fly I'll have to fall back on "what I feel looks like"
There will be a video posted later and you guys can be the judge.
Expat flyer.
normally I wipe the sheeting with a damp rag just before I start bonding if I want it to foam. evaporation inside the structure provides more than enough moisture for a good bond.
Thanks for the input guys I'll be back with closing up the wing Monday.
B-58 Hustler 4 edf's ? Spitfireski Electric Ducted Fan Jet Talk 29 Nov 28, 2005 08:32 PM
B-58 Hustler project gutboy17 Electric Ducted Fan Jet Talk 34 Feb 19, 2004 06:03 PM
For Sale For Sale: 12-inch long 4-40 Threaded Rods with Clevises, 36 per package Sled Driver Aircraft - Fuel - Airplanes (FS/W) 0 Nov 29, 2003 07:02 PM
Micro B-58 Hustler flailing Scratchbuilt Indoor and Micro Models 7 Apr 17, 2002 03:43 PM
Micro B-58 Hustler flailing Electric Ducted Fan Jet Talk 0 Apr 17, 2002 12:57 PM
