Old Feb 02, 2008, 08:00 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Honey Bee FP noob questions
Long time fixed wing, heli noob.
Q: Why do both (Lama and Honey Bee) Esky heli swashplates separate for no good reason? No crash, hard landing etc, just in the course of normal use.
I've replaced them , still the same? Is there some special shaft height/servo arm combination? On the Lama I "fixed" the problem by putting plastic spacers on the shaft under the swashplate to physically prevent it from separating -
Should I just get metal swashplates??
kelberts is offline Find More Posts by kelberts
Old Feb 03, 2008, 03:38 AM
sparkysko is offline
Find More Posts by sparkysko
Unshaven yokel
sparkysko's Avatar
Portland, Oregon
Joined Oct 2007
You should glue them. You can't get a metal swashplate for the honey bee anyways, and I don't recommend the lama metal swashplate.
Clean off the mating surfaces, and put a VERY SMALL (not even a drop) amount of CA on a toothpick and use that to rub around on the mating surface and shove it back on. I have never had a swashplate separate again after doing this.
sparkysko is offline Find More Posts by sparkysko
Old Feb 03, 2008, 11:28 AM
Vince Herman is offline
Find More Posts by Vince Herman
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
Sparky described the same fix that we used for early versions of the T-Rex swash that separated.
Vince Herman is offline Find More Posts by Vince Herman
Old Feb 03, 2008, 11:55 AM
Realmkaos is offline
Find More Posts by Realmkaos
Dragonus II Plus
Realmkaos's Avatar
Outside Philly
Joined Jun 2007
I also say to glue the 2 pieces together. Had to do it on both my helis. Works great. But as Sparkysko said, be careful to use VERY little.
Realmkaos is offline Find More Posts by Realmkaos
Old Feb 03, 2008, 04:00 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
Put a drop of CA on some spare plastic, then use a pin to transfer just the amount you want.
My HBFP swash separated in flight and the heli drifted away down wind, but it was still really stable so I didn't realise that I had no control, I just thought the wind had got stronger...
RobinBennett is offline Find More Posts by RobinBennett
Discussion About to buy a Honey Bee FP Mark 3, final questions wilsgrant Micro Helis 41 Sep 22, 2007 04:29 PM
Discussion Noob needs help with Honey Bee FP - please! blkdog7 Micro Helis 31 Sep 13, 2007 10:08 AM
Discussion Honey Bee FP Questions lmnelson Micro Helis 52 Jun 18, 2007 10:54 PM
Discussion Honey Bee FP parts+battery questions bp_968 Mini Helis 3 Jun 07, 2007 02:04 PM
Honey Bee FP and FP2 Questions adamkerrnz Micro Helis 3 Oct 13, 2005 11:34 PM
