Old Feb 19, 2008, 10:25 PM
segraves is offline
Find More Posts by segraves
Joined Jan 2007
Originally Posted by segraves
Here is the procedure to scale and tile the hi-res 3-view at www.skyote.org to 30" WS. The hi-res 3-view (a 300 dpi letter-size JPEG image) has Wing Span (WS) = 4.32 inches. Really! If your image-editing software tells you otherwise, it was probably made by M$. ;-) Here's a way to tell. Run the image through ScaleAndTile, same 3-step as below, but with SF=1. See that the resulting single-page PDF is 8.5"x11". Print a copy. Measure the WS carefully with an accurate scale.
The image is buried deep in the www.skyote.org site. Here's the link:
http://skyote.org/Gallery/Miscellane..._3_View?full=1
The above link appears to be dead, for now. I haven't been able to find the 3-view since www.skyote.org changed to another ISP. Fortunately, we already have the original high-res 3-view, right here in this thread. I'll correct the link when/if it appears on the Skyote web site.
Thank you, Google. Wish I'd bought your stock when my sister did. ;-)
3-Step Procedure
1. Scale Factor (SF) = WS (model) / WS (3-view) = 30 / 4.32 = 6.94
2. Launch ScaleAndTile2.
3. Enter "Skyote_3_View.jpg", "6.94", "SS30.pdf", "LETTER", "SS30_tiled.pdf" (Leave out the quotes when you enter the data), and click on the "Do it!" button.
Voila! Plans happen! The above 3-step procedure can be performed in about 1 minute with ScaleAndTile2 (or ScaleAndTile, with its default letter-size tiles). Of course, the program runs in much less time (about 3-1/2 seconds on this 133MHz Toshiba laptop), depending on the speed of your computer. Results to be posted later. [Edit: See post #7 for results, with "SS" expanded to "SimpleSkyote" in the names of the uploaded files.]
Cheers,
Bill Segraves
segraves is offline Find More Posts by segraves
Old Feb 19, 2008, 10:57 PM
segraves is offline
Joined Jan 2007
Here's a link to several articles on the Skyote, including Bob Hoover's 1976 pilot report:
http://www.skyote.org/What_is_a_Skyote.html
Cheers,
Bill Segraves
Old Feb 20, 2008, 07:12 AM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Cheers,
Bill Segraves
P.S. See sample output produced by ScaleAndTile3, v3k, below.
P.S.2. Tony/Kendall, how about an easy adaptation of the monoblock fuse of the Pawnee, with J-3-Cub-ish nosebowl, Tiger-Moth-ish empennage, and swept J-3-Cub-ish wings?
Bill, it can be done fairly easily. What are you looking for? i.e., size, weight, park scale or true scale, airfoil, flying characteristics, etc
Tony
Tony65x55 is offline Find More Posts by Tony65x55
Old Feb 20, 2008, 11:13 AM
segraves is offline
Joined Jan 2007
Tony
Tony, I'll defer to your expertise. If you'd like to take it on, please proceed.
I'm thinking a standoff (semi) scale sport aircraft, similar in size and performance to what works so well for your designs, would be best.
The high-resolution 3-view I posted is the best that is available, and I have permission from Pete Bartoe for it to be posted and used here.
So, let's move it forward, whenever you're ready. There are plenty of nice color schemes available on the Skyote Club and Yahoo sites.
Many thanks and best regards,
Bill Segraves
P.S. I'm in hopes you'll have a working design in time for Kendall's safe return, so he can giant-size it (prayer for his safe return).
Old Feb 20, 2008, 03:18 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
OK, you gonna do the beta build?
Tony
(praying for Kendall too) (All the other great guys there too)
Old Feb 20, 2008, 04:15 PM
segraves is offline
Joined Jan 2007
Tony
Sure, I'm in. OTOH, perhaps we should also enlist someone (Bob?) that would get it flying faster than I might. I'd certainly like to participate, though, to the extent my wife's health will permit it. I have a lot of sofa time, as she is often sitting in the den because that's the most comfortable place to ride out her constant pain.
Just let me know what materials we'll be using, and I'll start laying them in.
I can run a ScaleAndTile3 job on it, as soon as you determine the wingspan we should use. Naturally, we'll keep the build and your detailed plans under wraps as long as you, the leader of the pack, require.
Glad I bought my wife an Olympus FE-280 digital camera for Christmas for us to use. I'm sure it will get good use on this project.
Many thanks, Tony, for your willingness to take on this project. I think we'll be able to use it to help promote the Skyote, both as a model and as a full scale airplane.
Best regards,
Bill Segraves
Old Feb 20, 2008, 08:38 PM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
OK Bill, drop me a PM with your e-mail on it. There are several executive decisions to be made.
Tony
Old Feb 21, 2008, 06:58 PM
segraves is offline
Joined Jan 2007
Originally Posted by gpw
Nice looking plane ...got plans ??? hahahahaha
Plans are in the works. Can't say any more right now, except it will probably be a 30" WS foamy.
Cheers,
Bill Segraves
Old Feb 21, 2008, 07:11 PM
segraves is offline
Joined Jan 2007
Unfortunately, the 3-view in message #7, which was the highest resolution 3-view available when it was uploaded, was downsampled by RCGroups to a lower resolution.
Not to worry, though. The PDFs I posted are based on the original high-resolution JPEG file, so they are the best we have available of Pete Bartoe's original 3-view drawing, at least until the file is restored on www.skyote.org.
The 1x and 6.94x PDFs that are posted in this thread can be scaled to any size the user desires. A plea, however: Please don't import them into an image editor that degrades the quality of them, as that might relect unfavorably on Mr. Bartoe's excellent work. The PDFs, as presented, can be scaled to any size, with no loss of the original resolution, if you stick with ScaleAndTile.
I'll check from time to time at www.skyote.org to see when the original 3-view is back online, and will let everyone know via this thread.
Best regards,
Bill Segraves
Old Mar 05, 2008, 09:35 PM
segraves is offline
Joined Jan 2007
Skyote Pirep by Budd Davisson - a must read!
The Skyote, an exquisite little biplane designed over thirty years ago by O.E. Pete Bartoe, is the subject of this design-build-fly thread.
I mentioned this as a possible project back in the Simple N-28 thread. At the time, GPW, et al, had too much on their plates to take on the project. Perhaps now that days are shorter, some of the Simple N-28 build participants will be able to contribute.
For those interested in digging deeper, The Skyote Type Club has a web site at www.skyote.org. In addition, there is a Yahoo Group, http://groups.yahoo.com/group/SkyoteTypeClub, that has more information on the Skyote.
Now, here's a tidbit for those who may read the available literature on the Skyote. The original name of the design was "Tiger Cub" (I saw the ghost (remains from erasure) of the original name on my copy of the plans), later changed to Skyote. I asked Pete Bartoe about this when I noticed it, and he explained his reasons for the change (later). I still think the original name is most appropriate.
Tiger Cub - you read it here first. AFAIK, this name has never appeared in published print media, and has probably been seen only by holders of copies of the plans (revealed simultaneously on Yahoo Groups).
More later. ...
Cheers,
Bill Segraves
O.K. I promised more later. Later is now here.
Please see Budd Davisson's Pirep here:
http://www.airbum.com/pireps/PirepSkyote.html
Tony and I have been working on a Monoblock-based 30" wingspan Skyote foamy, for which we've worked diligently to achieve near-scale appearance, and hopefully, the performance for which Tony's designs have achieved legendary status. I've asked Tony to start a new thread under his own name, so he'll get the recognition he so richly deserves, when we have it ready for release in the wild. ;-)
Watch for it, soon.
Best regards,
Bill Segraves
Old May 16, 2008, 01:46 PM
segraves is offline
Joined Jan 2007
Skyote 1/8-scale coming soon - Beta builders needed.
Attention: Beta builders
Pat Tritle is doing a 1/8-scale L-4 over in the Scale Electric Models forum. Check out the cowl-engine combo here:
http://www.rcgroups.com/forums/showt...17#post9761054
It should be a perfect fit (when adapted) to Tony's 1/8-scale Skyote, coming soon.
Cheers,
Bill Segraves
Old May 16, 2008, 06:32 PM
segraves is offline
Joined Jan 2007
While we're waiting for the final plans from Tony ...
While we're waiting for the plans Tony will post later, readers who feel compelled to have a really accurate fuselage might enjoy seeing the isometric view of Cartesian Tubes, Inc's profiled-tube kit for a real Skyote fuselage, here:
http://www.cartesiantube.com/Catalog...e/Default.html
Builders using Tony's monobloc method for fuselage construction will be flying a lot sooner than true-scale builders.
Thanks, Tony. We look forward to seeing the final plans.
Warmest best regards,
Bill Segraves
Old May 24, 2008, 06:59 AM
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Bill, thanks for all your patience. Here are the plans for the 30" Skyote. Enjoy!
Tony
PS: PLANS AMENDED ON JUNE 12/08
Old May 24, 2008, 07:09 AM
Hopalong X is offline
Find More Posts by Hopalong X
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Tony
I've been waiting on these!
Hopalong X is offline Find More Posts by Hopalong X
Old May 24, 2008, 08:15 AM
segraves is offline
Joined Jan 2007
Tony
Tony, many thanks for all you do for Foamies (Scratchbuilt).
By your extraordinary efforts, potential Skyote builders have gained access to plans much earlier than they would have if I had undertaken to do them myself.
Now, let's get a few Beta builders to work on the Skyote, perhaps some of those who have done Beta builds on some of your other successes, if they're ready and willing to participate.
I'm sure Nettie will be proud of "Miss Nettie". The models of the Skyote are one way I can avoid building a 1:1 scale version, flying same with me in it. Nettie is most grateful for a version that will keep me on the ground.
Bill Segraves
P.S. Note to builders: You can find color schemes for various full-scale Skyotes at www.skyote.org.
AIAA Design, Build, and Fly! foss1997 Electric Plane Talk 12 Nov 26, 2009 11:14 PM
Build Log Simple Nieuport 28 - design-build-fly by GPW, MS, Jasta_66, stanordave, et al segraves Foamies (Scratchbuilt) 143 Aug 09, 2008 02:03 PM
36" Purdhismee DLG Design build and fly thread :) FairlyFaded Hand Launch 7 May 29, 2005 12:39 AM
What ever happened to the EDF design/build/fly contest. OCModels Electric Ducted Fan Jet Talk 2 May 13, 2002 04:10 PM
AIAA/Cessna design,build,fly Travis Electric Plane Talk 6 Apr 24, 2001 05:58 PM
