Old Feb 18, 2007, 11:59 PM
Freddric is offline
Find More Posts by Freddric
Joined Feb 2007
Rant
Help with Brushless Prop for SS
Hi everyone,
This is my first r/c plane, it's a GWS SS. I've finally got all the electronics working. But my problem now is. How do I attach my Prop to the prop shaft of the Himax HG2015-4166 brushless motor that I have. There are no instructions for this to be found. Can anyone help. I've posted an image to show the parts I have, but for the life of me I can't figure out how it's suppose to work.
thanks,
Fred
Freddric is offline Find More Posts by Freddric
Old Feb 19, 2007, 12:36 AM
fr4nk1yn is offline
Find More Posts by fr4nk1yn
fr4nk1yn's Avatar
Norfolk, Va
Joined May 2006
Prop attaches like in picture.
I assume the allen wrench is used to tighten the tip and the collet tightens to the gearbox shaft.
Since my collet didn't tighten to the shaft and I wanted to use the GWS props, like you also have, I bought a 3mm threaded shaft from the local hobby shop.
I also use a prop saver.
I only got one prop adapter with my motor. If neither fits your prop you may have to get an APC prop. From what I've read drilling the GWS prop doesn't leave much material in the hub area.
I hope this helps some.
fr4nk1yn is offline Find More Posts by fr4nk1yn
Old Feb 19, 2007, 01:10 AM
Freddric is offline
Joined Feb 2007
Hi MiseryQ,
I see, hmmm. okay I went ahead an also ordered a 3mm shaft and one of those cool prop savers. The lady at my LHS didn't have a clue how the prop fit. and this being my first plane I also had no clue. Thank you.
Fred
Old Feb 19, 2007, 11:09 AM
kcar is offline
Find More Posts by kcar
There are four lights!
kcar's Avatar
Santa Cruz, C.A.
Joined Jan 2005
I think your gonna have to drill out that prop, first off.
Then the thing with the threads goes on the shaft, then the round
thing with the flat facing out, then the prop, then the prop nut.
kcar is offline Find More Posts by kcar
Old Feb 19, 2007, 11:29 AM
TipStalled is offline
Find More Posts by TipStalled
Mark 12:30
TipStalled's Avatar
United States, GA, Alpharetta
Joined Jan 2004
All you need is the prop-saver for 3mm shaft. The shaft on the end of your Himaxx gearbox is 3mm. Most prop-savers have 2 different thicknesses (each side is different) to accomadate different props. Just flip it the way it is most secure with your prop. Most prop savers will use the 2 screws that tighten onto the 3mm shaft to loop the rubber-bandy thingy (highly technical term) around the prop. You are almost there !!
TipStalled is offline Find More Posts by TipStalled
Help with brushless setup for Formosa gwiz Power Systems 282 Jun 16, 2006 10:21 PM
Help with power rec. for SS AP dawkins Aerial Photography 1 Apr 28, 2005 08:52 PM
Need help with brushless power for GP Ryan EP jcrc Power Systems 3 May 23, 2003 10:14 AM
Help with what prop for this motor and GB Mike Parsons Power Systems 8 May 21, 2003 08:52 AM
Help with Batteries/Prop for Mega 15/16/4 Flying Low Batteries and Chargers 4 Jan 20, 2003 04:44 AM
