Old Mar 01, 2005, 11:22 AM
trav is offline
Find More Posts by trav
cornwall
Joined Mar 2005
Question
eco 8 probs
I have an eco running a performance motor with the correct pinion according to the manual. I have throttle and pitch curves from a sport motor and am running 8 cells. 2 days ago all was flying well, not tons of power but to be expected, the only prob was a lack of power around mid stick, tried loads of adjusting, but gave up. Today, same again and no idea why, any ideas would be greatly appreciated TVM
trav is offline Find More Posts by trav
Old Mar 01, 2005, 11:29 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
How many teeth on the pinion?
What's the pitch range?
What's your throttle and pitch curves?
Toshi
TMorita is offline Find More Posts by TMorita
Old Mar 01, 2005, 11:35 AM
trav is offline
cornwall
Joined Mar 2005
thanks toshi
Thanks for your interest toshi, the last message must seem rude just giving figures, for some reason only second half of message posted. Anyway try again, the specs are:
12 teeth on pinion, pitch curve 25 47 68 85 100, throttle 0-65-85-94-100 pitch range -2 to +9
Any ideas would be great as today, wasn't even comfortable in curcuits
Trav
Last edited by trav; Mar 01, 2005 at 11:43 AM. Reason: entered wrong for some reason
Old Mar 01, 2005, 01:04 PM
rockrob is offline
Find More Posts by rockrob
Joined Aug 2004
Trav, put your throttle curve at 0-100-100-100-100. Then adjust the pitch curve to where you are hovering at half stick. This should help! If you have governer mode on your esc, read up on that and set it as needed....around 1900 rpm for hovor and sport flying.
RW
rockrob is offline Find More Posts by rockrob
Old Mar 01, 2005, 01:18 PM
trav is offline
cornwall
Joined Mar 2005
thanks rob, what do I put the throttle curve to after I have set the pitch? I am using the standard ikarus speed controller and dont think it has gov mode, there is gove mode on my futaba ff9 transmitter but I don't know if this is helpful, any ideas?
Old Mar 01, 2005, 02:36 PM
TMorita is offline
Joined May 2002
Trav
If you're doing FF, this not a reasonable setup.
You are running a beginner-level semi-fixed-pitch setup.
You need to be using the idle-up mode and setting the throttle flat across at about 90-90-90-90-90.
This should give you a decent amount of power.
Also, since you are running a brushed motor, you should check if the commutator needs to be cleaned...this can cause serious power loss.
Toshi
ECO-8 tail rotor probs woots Electric Heli Talk 67 May 17, 2005 10:04 PM
eco 8 further probs trav Electric Heli Talk 13 Mar 03, 2005 08:03 AM
Fully upgraded ECO 8 W/JR 652, Jet ranger, Brushless Capt. Dave Aircraft - Electric - Airplanes (FS/W) 8 Sep 10, 2001 05:04 AM
ECO 8 / Jet Ranger airwolf Aircraft - Electric - Airplanes (FS/W) 11 Aug 05, 2001 09:20 PM
Eclipse 7 and ECO 8 Stig C Electric Plane Talk 1 Jul 01, 2001 06:17 PM
