Old Jan 24, 2005, 10:07 AM
thekingofmice is offline
Find More Posts by thekingofmice
thekingofmice's Avatar
Point Pleasant, WV
Joined May 2002
GWS Auto-cut question
I guess that this is kind of a stupid question but...
I have a regular 2 channel futaba system, and I want to build something simple for my kids to learn on (instead of endangering my planes and equipment.) Probably a rogallo-type plane. I thought that the gws auto-cut would be perfect, but very little documentation came with it.
As shown in the picture below (I hope) there are three connectors: an male and female battery connector and a rx connector. My question is: is this just intended to be a cheap replacement for an esc only? Or could you use a y connector on the battery and split the output between the rx and the auto cut so that the motor will still cut off at low voltage but the rx will still operate?
thekingofmice is offline Find More Posts by thekingofmice
Old Jan 24, 2005, 02:38 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
The auto-cut shuts down only the motor, leaving control to land. But be careful when you push start! That's wide open throttle until then. Stick with low Mah packs, cause it won't come down until the pack gets low.
Ron H is online now Find More Posts by Ron H
Old Jan 24, 2005, 03:53 PM
Point Pleasant, WV
Joined May 2002
Thanks for the reply! Ok, looking at it again I see that it has to be plugged into the RX in order to use the BEC. What was confusing me was that the RX that I have only has 2 channels and no separate plug for a battery. So the auto-cut won't be any use to me. It has to be powered through a BEC circuit, so I might as well use an ESC. It looks like I will have to use just throttle and rudder for the plane. (Unless I can disassemble the RX and find some way to hook the battery into it without using one of the channels.)
GWS battery connector question Steve Fehr Parkflyers 4 Mar 18, 2002 06:24 PM
GWS Heat sink question. Daveairway Parkflyers 2 Mar 14, 2002 09:18 PM
Question GWS Cub Motor Question ! Dan & son Bryce Parkflyers 9 Mar 02, 2002 08:38 AM
GWS DX-A motor question dshly Parkflyers 5 Oct 16, 2001 08:47 AM
GWS Tiger Moth Question - Battery Access? mrebman Parkflyers 25 Jul 06, 2001 08:23 AM
