Old Jun 14, 2014, 01:01 AM
hihptsi is offline
Find More Posts by hihptsi
hihptsi's Avatar
Illinois
Joined Apr 2005
Motor Recommendations on 3kg quad for Endurance.
I am building a 650 size quad that will be approx. 3kg MAX AUW. I would like to know what some of you recommend as far as motor and prop choice for max flight time in easy forward flight. I have a couple motors in mind ( multistars or Tmotors), but I thought id check in here with others to get other ideas as far as choices and what worked for you. im sure someone here has some recommendations!
Thanks!
hihptsi is offline Find More Posts by hihptsi
Old Jun 14, 2014, 11:26 AM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
delete.
manuel v is online now Find More Posts by manuel v
Old Jun 15, 2014, 04:02 AM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
Originally Posted by manuel v View Post
delete.
Wow, Thanks for taking the time out to make such a thoughtful comment.
Old Jun 15, 2014, 03:14 PM
manuel v's Avatar
Joined Aug 2004
I'm sorry, you got an answer considering your multirotor was a hexa.
When I saw that this is a cuadra immediately delete it and for now I could give you another answer.
Manuel V.
Old Jun 15, 2014, 04:10 PM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
So manuel, do you have a proven recommendation considering its a quad, with a 3kg AUW. I am just looking for other options besides some of the ones i've been looking at. I ask here because this is a forum with vast experience in the matter and your opinions carry allot of weight.
Old Jun 15, 2014, 06:07 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Suggestions:
MT2814 770KV with 13x4.4CF props on 4S battery
http://www.rctigermotor.com/html/201...s_0916/77.html
U5 400KV with 14x4.8CF props on 6S battery
http://www.rctigermotor.com/html/201...e_0928/91.html
Mortimer is offline Find More Posts by Mortimer
Old Jun 15, 2014, 06:55 PM
manuel v's Avatar
Joined Aug 2004
Y have this numbers with HK 14x4.7 propeller to 175% thrust.
To 3s:
Kv= 581
110-129 g motor.
200 watts in for motor.
Manuel V.
Old Jun 15, 2014, 11:17 PM
hihptsi is offline
hihptsi's Avatar
Illinois
Joined Apr 2005
thanks for the input guys! One of the multistar motors I am looking at is located here. http://www.hobbyking.com/hobbyking/s...arehouse_.html
id like to run 15" cf props on this, but am open to extending the booms to run 17" props. What do you guys think of this motor?
Old Jun 22, 2014, 08:37 AM
Hiway is offline
Find More Posts by Hiway
Dirty Side Down.......o~^o
Hiway's Avatar
United States, MD, Sharpsburg
Joined Mar 2014
From my research and the time spent with ecalc as well as pouring over specs from Sunny Sky and Cobra, I suspect the best choice, with the most likelyhood of acheiving your goal is going to be the Sunny Sky 3508 29 380kv spinning 15in props with 5S lipos (the 6S run a bit hot according to specs- I like to see the temps around 50 degrees c at max)
At 50% throttle you get around 600g of thrust pulling only 2 to 3 amps and 64w
Also- they are in stock... few folks will consider them as they are designed for the 5S and 6S lipos... but they appear to be quite the little torque monsters.
Hiway is offline Find More Posts by Hiway
Discussion Motors for 2,3kg - 3S zzmetalname Multirotor Talk 3 Jun 08, 2014 03:40 AM
Question Instability. Need Naza gains for light weight endurance quad. Daemon Multirotor Talk 4 Mar 28, 2014 02:29 AM
Discussion Bixler 1.1 long range / endurance - motor / prop recommendations jwmachon Electric Plane Talk 6 Feb 06, 2014 03:04 PM
Question Recommendations on Motor/ESC combo marcuskeeler Multirotor Power Systems 2 Oct 16, 2013 02:57 PM
Discussion Recommendations for a low Kv motor for 6s quad Fergus Multirotor Talk 7 Nov 18, 2011 03:34 PM
