Old Apr 12, 2014, 09:36 AM
psjdb is offline
Find More Posts by psjdb
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Looks really nice, thanks for info, I made up a thrust tube which has fitted up nicely with around 72mm outlet plus been soldering up all the wiring and installing all in the forward nose section the last week, but progress is slow due to being very busy at work and repairs on a few other planes, hopefully will get a bit more done in the next week or so.
Cheers, good luck with the first flights.
psjdb is offline Find More Posts by psjdb
Old May 04, 2014, 02:33 PM
psjdb is offline
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Installed most of the electrics tonight, and tested the operation.
Just a question from those who have flown skyhawks, Jepe recommended using delta wing mixing to help out the small elevators have you guys done this or found the elevators enough on their own ??.
Cheers.
Old May 05, 2014, 10:44 PM
Straight Up is online now
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
Cheers.
This sounds like a very bad idea. The Skyhawk has a delta wing, but it is NOT a delta plane. Up aileron will not give the same response as up elevator. This "tied control" was a big fad when the first small foam jets came out. I had a Wattage F86 Sabre that had it, and it was a dog. Up elevator also gave up aileron, causing the wing to dump lift and splat during landing flare. Conversely pushing the nose down gave a "flap down" effect, boosting left and also making the wing more prone to stall. The obvious response is "then reverse the coupling"... no, don't do that neither. The elevators might be small but they have a much longer lever-arm from the CG than the ailerons. If you need more elevator effectiveness use more control throw and/or shift your CG back (a little bit at a time). Beware that CG position is critical for jets, where the lack of prop wash means you have reduced elevator effectiveness at low speed. A forward CG works OK at high speed but you'll struggle to keep the nose up at low speed.
Straight Up is online now Find More Posts by Straight Up
Old May 06, 2014, 11:12 PM
psjdb is offline
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Ah that's just the answer I wanted to hear, makes it simpler for me with out all that mixing .
Cheers
Old May 11, 2014, 07:24 AM
psjdb is offline
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Kids !!! deleted my decal files so made up my own Tiki emblem showing a little more detail so here it is for anyone who wants one latter with out going through the pain I did lol.
Cheers.
Old May 12, 2014, 05:37 AM
psjdb is offline
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Some more progress, finishing the top wing, still needs clear coating though also fitted up some cannons I made up the other night !!.
getting there slowly !!.
Old Jul 09, 2014, 08:56 AM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Looks good, I used to work on these. I did the GWS foam one a few years back in the single green all over scheme, and it was a handful to keep orientation on.
lesterpk is offline Find More Posts by lesterpk
Old Jan 10, 2016, 05:11 AM
psjdb is offline
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
Wow been a while !!, had and unsuccessful maiden due to landing gear failure on take off, did a bit of damage to her, then had to move from one side of Australia to the other for work, so my planes were in storage for a long period of time.
Finally got my planes back and have slowly been getting them up and flying again !!.
So started on the Skyhawk repairs after new years, fixed all the damage to the glass on the fuse, then fitted the avionics hump as I have now decided on an early eighties scheme in the SEA cam with the light bottom for better orientation after comments on this thread about the all over scheme.
Also have a bungee launcher up and running and have spent this month perfecting hook placement and launching with my mirage 4000, SO the gear has gone on the Skyhawk which should cut some weight as well.
pics as usual .
Old Jan 10, 2016, 11:36 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Looks great there is a need for a good 90mm sized A-4.
AIR SALLY is online now Find More Posts by AIR SALLY
Gallery JePe A-4 Skyhawk Haldor Your Plane Photos 0 May 10, 2004 10:16 AM
Gallery JePe A-4 Skyhawk underside Haldor Your Plane Photos 0 May 10, 2004 10:15 AM
Gallery JePe A-4 Skyhawk Haldor Your Plane Photos 0 May 10, 2004 10:14 AM
Gallery A-4 Skyhawk by JePe Herb Your Plane Photos 1 May 06, 2004 12:27 PM
JePe A-4 Skyhawk Sture Smidt Electric Ducted Fan Jet Talk 51 May 28, 2002 02:04 PM
