Old Aug 13, 2013, 08:07 PM
paulywood is offline
Find More Posts by paulywood
paulywood's Avatar
United States, CA, Sacramento
Joined Feb 2003
Help!
RFM Offset Yoke & Spinner
I have & setting up a RFM Offset Yoke & Carbon Spinner with RFM 17 x 13 prop.
Does the Offset put more pitch in the Blades?
How do I know if it's a +5 or +7 degree Offset?
Thanks, Paul.
paulywood is offline Find More Posts by paulywood
Old Aug 14, 2013, 02:14 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I think that you may be confusing offset with twist in the yoke, they are two separate things I believe.
The offset, when the yoke is an "S" shape when viewed from the front, is simply to make the prop blades sit flatter against the fuse, making the folded blades more streamlined than what they would be without the offset. F5B planes use these frequently. It doesn't change the pitch at all
Twist would make the blades pivot not in line with the fuse, so for a high performance plane, you should avoid it I would think. I'm not sure about this last point.
A call to Soaring USA should get you the answer. Talk to Gary or Bob.
R,
target
target is offline Find More Posts by target
Old Aug 14, 2013, 03:02 PM
paulywood's Avatar
Joined Feb 2003
R,
target
Thanks, target
I've been doing my research.
Paul
Old Aug 14, 2013, 06:03 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I saw that Paul.
Its interesting that the terms seem to be the opposite to what would be logical.
You have forced me to learn about something I would never have, and for that, I thank you! :-)
R,
Target
Old Aug 14, 2013, 11:47 PM
paulywood's Avatar
Joined Feb 2003
Keep learning my son, I always do.
pauly
Sold Graupner Spinners & Yokes joesoar Aircraft - Electric - Power Systems (FS/W) 1 May 22, 2013 06:07 PM
Discussion RFM Folding prop-spinner offset question? kilwein Electric Sailplanes 6 Jan 05, 2013 08:10 PM
Discussion RFM offset spinner failures jjmouris High Performance 55 Feb 07, 2010 05:08 AM
Discussion 40mm / offset yoke spinners pilotrcuk Electric Sailplanes 2 Oct 25, 2009 03:02 PM
Found RFM 17x18 with 38mm +5 degree spinner and yoke verticalflight Aircraft - Electric - Power Systems (FS/W) 0 Feb 18, 2008 10:46 AM
