Old Feb 21, 2013, 11:34 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The same "mix" was also present on the Mhz version of the buggies, which have only full speed forward, reduced speed backward, and left/right. As soon as you steer, the throttle it considerablt reduced. Although I did find that the reduction did vary, some buggies corner much faster than others. I thought it was due to the coil and magnet steering on those, but if it's also present on the proportional versions, it's by design. With the ones with no proportional speed control, it really has an advantage as you can use "blipping" the steering to reduce the rpm as you accelerate on a slippery surface. But I fail to see the added value of this when having better speed control. I agree, it's only limiting the options to go spinning.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Feb 25, 2013, 06:25 PM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
I got a buggy and car, I've got a few pictures I will upload later.
I checked the speed with the tamiya mini-4wd speed checker.
Both seem to use the same connector and polarity as popular UMicro batteries, like E-flites.
My opinion of both cars:
The buggy:
I have a soft spot for buggys, and this is the coolest looking little thing.
It has headlights that operate when moving forward, taillights for braking/reverse, the esc has forward/reverse/ and a very effective brake.
Swing arm front suspension in the front, motor pod in the rear, all 4 springs are replacable, it seems to use mechanical pencil,clicker pen type springs for the front and slightly larger for the rear. Rear suspension travel is a little compromised in the compression department due to clearance with the chassis/body, but it can articulate ok.
It does have a servo for steering, it is a 5 wire servo with a standard shape servo case, it lays down facing forward.
Top speed 9 k/ph on the speedchecker and 6 k/ph when you turn the wheels or go in reverse. For comparison Mini-Z overlands and monsters did 11 to 12 k/ph on the speed checker.
You can open and completely dissasemble the car (atleast I think so, I really only did that for the chassis and front end.)
The locked diff helps tons for offroading, it doesnt affect anything else other than turning radius and it will push under throttle.
Overall its a neat little chassis, I wish there was an elegant all in one receiver/esc that operates on a 1s lipo to replace the factory servo and electronics.
Since its a buggy the wheels are exposed and will give a lot of kickback to the servo when you bump and crash, my servo slightly stripped in the second charge.
And like most RC vehicles, a tighter turning radius would be nice.
The car:
Its like most mini rc cars with sliding link front suspension and a motor pod in the rear, it has even more compression travel issues than the buggy with the motor pod sticking if you push it down, but it does articulate left and right just fine.
12 k/ph forward and 6 k/ph turning/reverse, for comparison my stock Mini-Z racers do 15 to 18 k/ph.
Locked diff makes it plow under power, but boy does this thing have startling acceleration! It hits 12 k/ph really quick.
It has headlights that operate when moving forward, the esc has forward/reverse/ and a very effective brake.
Like the buggy its turning radius could have more travel, unlike the buggy the battery lid has no retension mechanism other than just slightly pressing it in, so unfortunately lots of bumping can loosen the lid and drag on the floor causing the car to spin.
Since this is lighter/smaller/with protected front wheels and small rear wheels, the car seems like it will last much longer with less drivetrain breakage and front servo breakage than the buggy.
The throttle dropping when steering is a downer for racing, but since the car goes so much faster in a straight line it seems like trying to minimize turning and maximize straight line distance would work as a legitimate racing tactic, I had
lots of fun lapping in a 6'x8' RCP track oval, which the car drove perfectly over.
pach is offline Find More Posts by pach
Old Feb 26, 2013, 02:40 PM
misterpepper is offline
Find More Posts by misterpepper
Joined Jan 2013
Great update. Thanks Pach. I'm not getting the same sticking in the rear suspension you are. I have the Lamborghini. But I wasn't getting much rear suspension travel, either. I opened it up and moved some wires for the rear lights to the rear of the motor pod and that helped, giving me about half as much travel in the rear as in the front now. My battery cover does have a little tab and I haven't had any problems with it coming loose. I agree about the quick acceleration. They are pretty light. I think I'm going to add a little bit of weight to mine, actually, to make it handle better on low pile commercial carpet because as of now the front end wants to bounce around too much. With any luck a little weight will give it a bit more traction for when the throttle jumps coming out of a turn.
misterpepper is offline Find More Posts by misterpepper
Old Jul 08, 2013, 12:24 AM
getsonrc is offline
Find More Posts by getsonrc
Joined Apr 2012
These ones seem a lot a like. Has anyone bought one of these hummer trucks?
getsonrc is offline Find More Posts by getsonrc
Old Mar 04, 2015, 10:12 PM
Plane Insane RC is offline
Find More Posts by Plane Insane RC
BUZZ KILL
Plane Insane RC's Avatar
Utah
Joined Aug 2010
I just picked up one of these cars. I built a 10 by 10 track in my basement. The car is really fun except for when you turn it really slows down. I took it apart to see if there was anything I can do to make it not slow down but unfortunately I don't know enough about electronics to know what I'm looking for. Does any one know how to mod the car so it doesn't slow down when turning?
Plane Insane RC is offline Find More Posts by Plane Insane RC
Old Mar 05, 2015, 01:20 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I'm afraid the slow-down feature is built into the cars, so you would be looking at having to replace the entire electronics with hobby grade stuff.
If the cars still operate on 2.4 volt Nimh, you could replace it with a small 1s LiPo. This is what I did when our daughter and I got tired of the low cornering speed. It gets a great boost in power, but handling still stays primitive, as we have the MHz version, that has no speed control, and no proportional steering. Eventually we got tired of these limitations, and used the buggy bodies, which are very cool, to the HPI Q32 micro cars. Especially the blue/white buggy body bolts right on with 2 patches of double face tape:
The other bodies took a little more tinkering, but also fit well:
The Q32 is not perfect, but it does allow to give full throttle in the corner, should you want to, and has more "proper" controls: http://www.rcgroups.com/forums/showthread.php?t=2304753
Sold (2) AR6100e Spektrum 2.4ghz Rx / (1) DX7 Tx / (2) BEC / (2) MicroDAN Motors smittycm Aircraft - General - Radio Equipment (FS/W) 9 Jan 15, 2013 09:54 AM
Discussion Nitrorcx has a nice deal. 1/10 Exceed RC Brushless PRO 2.4Ghz Electric Dynamite RTR Craymar Hot Online Deals 3 Oct 23, 2012 09:55 PM
Video This Week in R/C 9, New 1/5th Cars, Nitrorcx Teaser, Fun Fly, T-28 Trojan Giveaway an hobbypartz Electric Plane Talk 0 Sep 03, 2011 12:11 AM
Sold Exceed RC 2.4Ghz 1/10 Electric Drift Car 4x4 for sale $149.00 free ship HelisZone Cars - Cars and Parts (FS/W) 1 May 27, 2011 02:05 AM
Discussion Why so few sub- 1/18 scale cars on 2.4GHZ? bfaulguy Micro Cars 9 Mar 09, 2011 07:10 PM
