Old Dec 22, 2012, 05:47 PM
hazegry is offline
Find More Posts by hazegry
Joined Sep 2006
what paint to use need a white that wont yellow
ok guys I painted my African queen with rustoleum gloss white it looked great put it on the shelf for a bit and now its a yellowish brown. I don't smoke so that's not it. I need something I can use and I would prefer to not have to strip the rustoleum the hull is a thin ABS plastic so I don't want to have to use stripping agents on it. I am open to all suggestions.
hazegry is offline Find More Posts by hazegry
Old Dec 23, 2012, 07:18 AM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
I would recommend wiping down the hull with denatured alcohol. This will remove the oils from finger prints and dull the gloss so the new paint will adhere better. I have used Plastikote white paint and it has not yellowed, however I have not used it on ABS. Try it on a piece of scrape first. Plastikote is my for choice for can spray paint.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Dec 23, 2012, 09:07 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
I have had no problem with krylon turning yellow but have with testers enamel and other enamels. I add a drop or 2 of blue into white when I use my airbrush. That stops any yellowing, keep in mind that that would be 2 drops to a 1/2 pint of paint.
charlie eaton is offline Find More Posts by charlie eaton
Old Dec 23, 2012, 11:45 AM
papower is offline
Find More Posts by papower
papower's Avatar
Joined Nov 2005
I have a model car that was built over 25 years ago and painted krylon gloss white. No clear coat. It is still as white as the day I painted it. Others painted with testors and other hobby paints have yellowed.
papower is offline Find More Posts by papower
Old Dec 23, 2012, 08:36 PM
hazegry is offline
Joined Sep 2006
thanks guys
Old Dec 23, 2012, 09:12 PM
chucksplanes is offline
Find More Posts by chucksplanes
United States, NE, Omaha
Joined Apr 2010
white paint
Originally Posted by charlie eaton View Post
I have had no problem with krylon turning yellow but have with testers emanel and other enamels. I add a drop or 2 of blue into white when I use my airbrush. That stops any yellowing, keep in mind that that would be 2 drops to a 1/2 pint of paint.
I agree with Charlie, I 've been into modeling for over 40 years . the drops of blue will do it.
chucksplanes is offline Find More Posts by chucksplanes
Old Dec 24, 2012, 12:26 AM
jerryj98501 is online now
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
In the sign shop I worked at part time, our painter added a couple of drops of aluminum paint into the white, said the aluminum helped with the reflective quality of the white. Jerryj98501
jerryj98501 is online now Find More Posts by jerryj98501
Old Dec 24, 2012, 12:37 AM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
[QUOTE=charlie eaton;23600496]I have had no problem with krylon turning yellow but have with testers emanel and other enamels. I add a drop or 2 of blue into white when I use my airbrush. That stops any yellowing, keep in mind that that would be 2 drops to a 1/2 pint of paint.[/QUOt
Will that work on my teeth?
MILLERTIME is online now Find More Posts by MILLERTIME
Old Dec 24, 2012, 05:26 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Adding the trace of blue sounds logical - in the elder days detergent sellers spoke of the "new blue whitener" that made things "whiter than white" only a decade or so after my granny used to sling a "dolly blue" (small sachet of weal blue dye on a stick) into the wash. The aluminium paint also sounds logical, anything to keep the UV away from the lower layers of white paint.
A passing thought - the white van parked down my street shows no sign of yellowing, how about touch- in paint from the local auto accessory shop?
mfr02 is offline Find More Posts by mfr02
Old Dec 24, 2012, 08:02 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Haze,
I had the same problem on an old styrene hull; my solution was a light sanding and a fresh coat of red. I don’t think I will have to worry about the yellowing again.
Kcal is offline Find More Posts by Kcal
Old Dec 26, 2012, 10:03 AM
N.E.Mass.
Joined Apr 2007
It seems that enamel will yellow. acrylic and lacquer will not. When I was in the USCG we would add blue to any white enamal that we used whether for a boat or a building to prevent the yellowing which is why I made that suggestion. It DOES work. Of course as KCAL said, a coat of red will cure it also
Old Dec 26, 2012, 01:33 PM
hazegry is offline
Joined Sep 2006
maybe I will paint it a nice tan I am not a big fan of white anyways
Old Dec 26, 2012, 05:47 PM
hazegry is offline
Joined Sep 2006
well I bought some yellow paint I figure if you cant beat them join em lol
Old Dec 26, 2012, 07:56 PM
hazegry is offline
Joined Sep 2006
well I think that fixes it if the Yellow with a green bottom doesn't look good I will switch the bottom to red oxide.
Old Dec 31, 2012, 10:42 PM
Kcal is offline
Joined Jul 2008
Ha ha, it drove me nuts too. I will try the add a touch of blue solution at some point; I thought white paint yellowed due to UV light degradation?
Personally I think the yellow and green combination came out really nicely.
Discussion What to use for painting glassed models? GreenAce92_v2 Sailplane Talk 7 May 21, 2012 08:05 PM
Question What kind of paint can be used on an Easystar> easystarfpv4 Electric Plane Talk 5 May 16, 2012 09:07 AM
Discussion To paint or not to paint that is the ? jmn6755 Electric Heli Talk 3 May 16, 2012 12:44 AM
Question Need advice for a 3D foamy that will use the electronics I have lying around Rota 3D Foamies 6 May 08, 2012 04:18 PM
Discussion what is the white silicon like glue that companies use nashiem Beginner Training Area (Aircraft-Electric) 5 Sep 24, 2007 09:16 PM
