Old Oct 10, 2012, 11:29 AM
ironhorse99 is offline
Find More Posts by ironhorse99
ironhorse99's Avatar
United States, NJ
Joined Sep 2012
Question
DH 9116 Controller Question
I have a question about adjusting the controller Mode/Sub menu.
In each menu section, Elev/Sub:Aile/Sub Etc. This is what I've set but am unsure of what it does. I'm assuming they are off-sets to further correct flight characteristics.....but its just an assumption. The settings are as follows:
Elev/Sub : Tri.F(8) 000
Aile/Sub : Tri.L (A) 000
Thro/Sub: Tri.F(8) 000
Rudd/Sub: Tri.L(A) 000
Now with the Up/Down buttons on the left of controller these settings can be adjusted +- 120. If adjusted down the symbols in parentheses appear. I'm assuming again that the (8) indicates Reverse and the (A) indicates Right.
Could someone with the knowledge please clarify for me what this Sub-Menu is used for & if my assumptions are correct and MORE IMPORTANTLY, what numbers should I use as a base and what do they represent. PLEASE, only respond if you can explain all this as I Confuse Easily.
ironhorse99 is offline Find More Posts by ironhorse99
Old Oct 10, 2012, 06:47 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
This doesn't help?
http://www.rcgroups.com/forums/showa...9&d=1345324334
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Oct 10, 2012, 07:48 PM
United States, NJ
Joined Sep 2012
Originally Posted by mikefromgermany View Post
If that's the Chinglish manual I have that......doesn't help.
Old Oct 10, 2012, 08:22 PM
tmodelli is offline
Find More Posts by tmodelli
tmodelli's Avatar
Orlando FL
Joined Apr 2009
those are subtrims. they exist to help center and fine-tune the main setup in the craft. once setup, they don't need to be touched anymore. We normally use those to center the servo 90 degree's before mounting in the heli.
With the latest flybareless controllers, radio subtrim is pretty much useless, as it would be giving the gyro input all the time, creating a drift, so the flybareless units have sub-trim embeded into its programing. However, on flybare machines, sub-trim is the best tool to center a heli.
--T
tmodelli is offline Find More Posts by tmodelli
Old Oct 10, 2012, 11:28 PM
Budasac is offline
Find More Posts by Budasac
Micro Menace
Joined Aug 2012
It's not "8", it's "B". And it's not "A", it's "R". So you have AIL "L"(left) and "R"(right). And THRO "F" (forward) and "B" (back). I don't use use Sub trim, or even trim really. I'd rather trim the heli itself than adjust the tx when possible..
Budasac is offline Find More Posts by Budasac
Old Oct 11, 2012, 02:36 PM
United States, NJ
Joined Sep 2012
I was close I suppose. I agree with you. The more I play around with the unit the more I discover. I just made a hardware adjustment to the right servo which always once the controller binded with the heli the right servo(as viewed from the tail-in position) would always pull down from the neutral position. So I disconnected the arm & moved it a little up so that when the unit binds it levels out neutral. Now when it takes off its very stable with almost no drift.
As for my original post it looks as though its a learn as you go kind of thing. I won't know what if any numbers I can use or what they mean unless & until I experiment with trial & error methodology.
Question Switching Controls on a DH 9116 Systematic Electric Heli Talk 6 Sep 25, 2012 10:15 PM
Discussion Will Mods on DH 9053 Benefit DH 9116 Fuzzyguy Beginner Training Area (Heli-Electric) 7 Jul 22, 2012 11:28 PM
Help! DH 9116 LCD settings question Sculptor Beginner Training Area (Heli-Electric) 17 Apr 20, 2012 07:15 AM
Discussion dh 9116 or blade 120 lloydd Mini Helis 3 Mar 31, 2012 08:12 PM
Discussion DH 9116 china model won't fly help. nick060200 Beginner Training Area (Heli-Electric) 9 Mar 07, 2012 10:18 PM
