Old Oct 09, 2012, 12:56 AM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
Terri,
Is the new Y6 going to have more room on the top plate for FPV camera (Horyzon HD) and a vTx...compared to your quad? Also, what size lipos have you tested on the Y6 and which size do you think works best?
sickwitit is offline Find More Posts by sickwitit
Old Oct 09, 2012, 10:57 AM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
Originally Posted by adrenahelin View Post
thanks! i'll check that out. i finally figured out the arduino 2560 driver is not for this board cause multicopter 2560 is ftdi, the ftdi driver loads ok and starts a com port but the upload doesn't work, tried 3 xp machines and 1 win7. (wife wasn't too happy when i hijacked her computer last night )
actually it's complicated - the 2560 has two drivers - one for accessing and making setting adjustments via the multiwii software (COM port) and the other for doing firmware updates... i found it easier to do the firmware via an external programmer.
macinr is offline Find More Posts by macinr
Old Oct 09, 2012, 12:57 PM
bobepine is online now
Find More Posts by bobepine
Team Armattan
bobepine's Avatar
Joined Jun 2011
This video is dedicated to Fester.
Armattan 290 Acro Flight (5 min 56 sec)
bobepine is online now Find More Posts by bobepine
Latest blog entry: Armattan F1 Lineup Revealed
Old Oct 09, 2012, 01:20 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
Fester shouldn't be upset, the X290 is closer to the thread title than Terri's Y6 IMHO.
Wasp09 is offline Find More Posts by Wasp09
Old Oct 09, 2012, 01:34 PM
Team Armattan
bobepine's Avatar
Joined Jun 2011
Hey there, Sir! Long time no hear from you. I haven't bothered you with motors questions for a while.
Here's hoping all is well with you.
Best,
Chris
Old Oct 09, 2012, 03:53 PM
adrenahelin is online now
Find More Posts by adrenahelin
United States, CT
Joined Mar 2011
thanks for the info.
adrenahelin is online now Find More Posts by adrenahelin
Old Oct 09, 2012, 04:48 PM
vpsporb is offline
Find More Posts by vpsporb
Canada, ON, Ottawa
Joined Dec 2011
http://youtu.be/6g9diq6OfAk
am i sensing love in the air....?
Aye, she's a very nice build... and a very nice sized quad to boot!
Your flying skillz are progressing Padawan san , luvn the delayed flips and tight turns.
vpsporb is offline Find More Posts by vpsporb
Old Oct 10, 2012, 03:43 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
X250 probem?
I have a problem with my X250 that I need some guidance with. I'm having a very hard time getting it to arm. I must repeatedly disconnect and connect the battery. Once I do get it to arm, the right rear motor only works very briefly (a few seconds). Then it starts to cog. When this occurs, I disconnect and re-arm again; repeat until several more times then give up. In total, the X250 leaves the floor for about 10 seconds and the battery is connected for maybe two minutes... for all attempts conbined. After the second attempt the right rear is pretty warm and will no longer do anything but cog. All attempts at offsetting this with trim changes are unsuccessful. After several minutes of fruitless attempts, the right rear motor is now hot, the others are room temperature.
It was flying previously to this incident. Is this a faulty ESC, motor or setup? The only time I ever encountered something like this was due to an ESC on a plane, but there are more variables with a quad.
BTW Chris, you are getting really good!
Balr14 is offline Find More Posts by Balr14
Old Oct 10, 2012, 03:46 PM
macinr is offline
macinr's Avatar
Joined Feb 2003
What was the "incident"? And what is "cog"?
Old Oct 10, 2012, 05:26 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Incident is probably the wrong word. It was flying before, normally and I recall nothing unusual happening the last time I flew it, no crashes, maybe a hard landing or two. I put it aside for about 6 weeks, never touched it. When I attempted to fly it after that, these symptoms started.
Cogging was also incorrect. On closer examination (I stuck my finger in the blade), the right rear rotor is just bouncing back and forth in the same position.
Old Oct 10, 2012, 07:26 PM
sprintr is offline
Find More Posts by sprintr
USA, IL, Chicago
Joined Aug 2007
where can I get props for the original 250 there was a link but can't find it.
thanks
sprintr is offline Find More Posts by sprintr
Old Oct 10, 2012, 07:48 PM
jer291113 is offline
Find More Posts by jer291113
Heli and E-Plane
United States, FL, Ocala
Joined Nov 2010
thanks
You can order them directly from Terri, send him a pm...
jer291113 is offline Find More Posts by jer291113
Old Oct 10, 2012, 10:01 PM
jsflyrv is offline
Find More Posts by jsflyrv
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
thanks
http://www.himodel.com/sort.php?sub1=E2
jsflyrv is offline Find More Posts by jsflyrv
Old Oct 11, 2012, 12:55 PM
Team Armattan
bobepine's Avatar
Joined Jun 2011
Hi Balr,
I hope you didn't go ahead and change a motor or ESC yet. I saw your post today but I was at work on my iPhone and couldn't reply.
What you appear to have here is a severed connection on the arm between the ESC and the motor.
You know how the ESCs connect to the arms and then the motors connect to the ESCs on the arms, too? Well, one of these circuit is broken.
There are three ways to fix this
1- scrape the arm so you can see the where the connection breaks out and add a dab of soldering on the break. This would not be the option I would go for by the way. Too redious and chances are you'll damage this further when scraping it.
2- replace the arm
3- Solder threes small wires directly from the ESC soldering points to the motors soldering points as to bypass the arms built in power grid. Then you'll have power going straight from your ESC to the motor and this should work. This is the option I would go for. Been there, dome that.
With a failing built in connection on the arm, there is not enough power reaching the motor so it can't spool up, yet, because it's getting some power but not spinning, it heats up
Hope this helps.
Best,
Chris
Old Oct 11, 2012, 01:11 PM
partzee is offline
Find More Posts by partzee
United States, AL, Guntersville
Joined Apr 2007
Hi Balr,
2- replace the arm
Hope this helps.
Best,
Chris
Bet Chris is right on with this.In the very old telephone days we referred to this as a "high resistance open". Weak connection causing high current on that circuit.
partzee
partzee is offline Find More Posts by partzee
Discussion Butterfly X250 Frame Quick Review/Photos flitelab Multirotor Talk 25 Jun 25, 2012 10:35 AM
Discussion Any more concise and beautiful than this mini X250 quadcopter goodluckbuy Multirotor Talk 13 Jun 16, 2012 10:54 AM
Discussion X250 carbon fiber xcopter. cyberbillp Multirotor Talk 0 May 11, 2012 09:06 AM
Sold butterfly-x250 Quad 4 sale new or trade for um plane crashdumby Aircraft - Electric - Multirotor (FS/W) 5 Apr 11, 2012 03:15 PM
Discussion MWC Starfire MWCores Flying Wings 7 Oct 04, 2009 11:38 AM
