Old Feb 26, 2012, 07:01 PM
felixk is offline
Find More Posts by felixk
United States, NJ, Fair Lawn
Joined Aug 2011
My motor seized and smoked..why?
Hi,
I was flying a mini pulse xt for a few weeks until I crashed it and had decided to buy a new motor. I bought a Park 480 1020kv, a 10x8 prop, and a 40amp ESC. Everything worked well until recently i noticed that if i throttle up too fast the motor would stop spinning and make a loud noise. After another 3 flights i landed and noticed smoke coming from the cowl. Everything looked fine inside, but the motor no longer worked.
What exactly happened? I researched the prop and ESC and made sure to get the correct ones for this motor. I've heard that motors will smoke if the prop is too big for it, but i don't think this is the case since it's rated for a 10x8 prop.
Anyone have any ideas what could be wrong and how i can prevent this in the future?
Felix
felixk is offline Find More Posts by felixk
Old Feb 26, 2012, 07:34 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
what about the battery/
Too big of a battery will fry a motor too.
RogueTitan is offline Find More Posts by RogueTitan
Old Feb 26, 2012, 07:36 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
You probably had timing problems before the meltdown. The usual symptom is a loud squealing sound as full throttle is approached. This is often resolved by programming the ESC for higher timing. Trying to operate the motor before resolving this problem probably resulted in overloading the motor.
whitecrest is offline Find More Posts by whitecrest
Old Feb 26, 2012, 08:11 PM
felixk is offline
Joined Aug 2011
Battery is just a 3cell 2200mah.
The timing was set to use: Standard which is:
STANDARD TIMING ADVANCE
Timing Degrees 15 & 20
Motor Poles 6 to 12
Expected Performance Good balance of power and efficiency
Motor Poles 14 or more
Expected Performance Best efficiency and run time (lowest power)
I can change it to:
LOW TIMING ADVANCE
Timing Degrees 5 & 10
Motor Poles 2 to 4
Motor Poles 6 or more
OR
HIGH TIMING ADVANCE
Timing Degrees 25
Motor Poles 12
Expected Performance Highest power, less efficiency
Which do you think would be appropriate?
Thanks!
Felix
Old Feb 26, 2012, 08:17 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
I'd try 25 degrees. Going higher seems to solve this problem with larger motors. Also, using a slightly smaller prop or lower pitch might make the timing less critical.
Old Feb 26, 2012, 08:19 PM
felixk is offline
Joined Aug 2011
Thanks i'll give it a try. Unfortunately i will need to spend another 50 bux on a new motor.
Thanks again for the help
Felix
tmb55 is offline
Find More Posts by tmb55
2 no or knot 2 no!
BC, Canada
Joined Sep 2009
the one that doesn't make the motor squeal. Please report back and let us know which one worked for you.
tmb55 is offline Find More Posts by tmb55
Old Feb 26, 2012, 09:13 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
You can get a replacement motor that size for a lot less than $50.
Ranandar is offline Find More Posts by Ranandar
Old Feb 26, 2012, 09:14 PM
felixk is offline
Joined Aug 2011
I will let you know when i try it.
Ranandar: I already ordered a new Park 480, but where do you buy your motors?
Old Feb 26, 2012, 10:31 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
felixk - this is said with dignity, respect, and love in my heart ... you need to read more of these threads!
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Feb 27, 2012, 07:02 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by felixk View Post
... What exactly happened? I researched the prop and ESC and made sure to get the correct ones for this motor. I've heard that motors will smoke if the prop is too big for it, but i don't think this is the case since it's rated for a 10x8 prop.
Anyone have any ideas what could be wrong and how i can prevent this in the future? ...
The most useful tool to prevent it in the future is a wattmeter like one of these http://www3.towerhobbies.com/cgi-bin...eter&search=Go.
Just because your motor is "rated" for a 10x8 prop, it's always good to check the actual amps yours is drawing, for manufacturing variation in motor and prop can make a difference to the amps. As it happens, the ad I've seen for your motor suggests 10x7 to 12x6, so for the highest recommended voltage (3S for this motor) you must use the smallest prop. So, with 3S, maybe 10x8 was simply too much for it. Without a wattmeter or ammeter, you wouldn't know.
abenn is offline Find More Posts by abenn
Old Feb 27, 2012, 08:30 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Another little hint. If it does squeal when you throttle up, get the throttle back quick. If you hold the throttle up and let it squeal, it will toast the motor in a matter of seconds. The ESC will also get very hot and in danger of going up in smoke too.
flypaper 2 is offline Find More Posts by flypaper 2
Old Feb 27, 2012, 08:55 AM
BrownEyedFool is offline
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Does that squeal you're talking about sound like a screeching bearing shrieking it's head off? If so maybe that's what's going on in my UM T-28. It's bone stock but if I take it to WOT it shrieks like a banshee, I've assumed it was the gearbox binding but perhaps a timing issue? Worth exploring since I've got replacements (stock) on the way to swap in.
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Feb 27, 2012, 09:10 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
For now, you might try a smaller prop. I have a little VTO Pogo that had to take off with full throttle to get it off the ground quick. It would squeal in protest till I advanced the timing. It would take off with no screaming after that.
Gord.
Old Feb 27, 2012, 09:37 AM
Joined Sep 2011
Hmm. Parkzone products are known for perfect internal config right out of the box, I have no idea how to check or change the timing in this unit. Couple that with some light blackening on the teeth of the main gear, it's less likely.
But I'll cease the hijack anyway and go to PM or micro rtf board.
Help! Brushless motor seems seized up???? Cutlass69 Power Systems 3 Feb 09, 2012 07:43 AM
Whoops! Doh! Smoked my LM 2.4ghz 500mW Vtx Slaphappysamy FPV Talk 2 Aug 22, 2011 02:13 PM
Discussion Could this be why my ESC smoked CaptainCarling Mini Helis 1 Jun 22, 2011 07:17 PM
Discussion Smoked My Phoenix 25, Not Sure Why tts3576 Power Systems 8 Jul 31, 2010 10:55 AM
Help! My heli motor smoked and apparently took my Phoenix 35 with it Sky_Dancer Castle Creations 1 Jul 16, 2007 11:38 AM
