Old Dec 06, 2013, 01:26 PM
SilbernerSurfer is online now
Find More Posts by SilbernerSurfer
I dont like crashes!
Germany, BY, M
Joined Jul 2013
Something similar to the Losi Micro-T from China?
Thanks in advance!
Uwe
SilbernerSurfer is online now Find More Posts by SilbernerSurfer
Old Dec 08, 2013, 09:52 AM
Moergo23 is offline
Find More Posts by Moergo23
Joined Apr 2010
i have seen rx l939 written on my l929 2,4 g rx board, so everything named wltoys l939 should be propo
as far as i know every l929 truggy with 2,4 ghz is propo, too
i tried some tuning, but it didnt work
i fit in a mcpx 200 mAh, but it did not increase anything. lipo is overloaded to 4,4 v because the charger did not stop charging. i don't try further because ther wasnt a power increasement
turnigy 1440 servo fits in with a very little bit of drilling and a little bit od dissassemling. i did not managed to get it working, but i will try
i dont expect it to be much better, its just for fun
the car is a surprise, i did not expect so much fun from such a cheap toy
i had a micro t a few years ago and out of the box it was not much better
differences to micro t
no diff
throttle/steering mixing (it only accelerates full throttle when you don't steer)
at first i hated this, now i like it
80's pan car like front suspension
@silbernersurfer
Amewi Running Dog als 2,4g Version
Moergo23 is offline Find More Posts by Moergo23
Old Dec 08, 2013, 01:31 PM
Germany, BY, M
Joined Jul 2013
Description on Banggood for the L929 says "Without proportional steering function":
Description:
Brand: Wltoys
Item No: L929
Frequency: 2.4G
Material: ABS Plastic
Color: Black, Blue, Red
Battery For Car: 3.7V 120mAh Li-Po Battery
Battery For Transmitter: 4*AA Battery (Not Incluede)
Charging Time: 40 Minutes
Playing Time: 6-10 Minutes
Control Distance: 30-40 Meters
Product Size: 10.5*8*5 cm
Age Range: Above 6+
Link:
URL says "L939", but it is "L929"
http://www.banggood.com/WLtoys-L939-...r-p-74946.html
WLtoys L929 without smooth rotation of the front wheels (0 min 28 sec)
Maybe i will give the L939 a chance.
This is the link for the true L939 from Banggood.
http://www.banggood.com/Wltoys-L939-...r-p-81755.html
At 7:30min in this vid you can see the proportional steering of the L939.
偉力L939短卡遙控車開箱及測試 (24 min 41 sec)
Great Wall 2209 has also a proportional steering. Lowers the throttle when touching the steering too.
No diff, so when it is slippery the front wheels have less grip in turns. You can open the battery box and put out the battery for charging. It is a pico plug. I can charge it with my para charging board. Unfortunately i havent found this batterys as spare parts.
Battery size Great Wall 2209: 23x12,5x6.6mm, 110mAh, Pico plug.
Old Aug 08, 2014, 11:13 PM
cyclops13 is offline
Find More Posts by cyclops13
United States, FL
Joined May 2014
Guys, any place to find the spare gears for the Wltoys L929? The gears which spin the rear wheels.
cyclops13 is offline Find More Posts by cyclops13
Old Aug 19, 2014, 12:29 PM
United States, FL
Joined May 2014
Bumping this thread again. Any place I can get the replacement gears for this li'l guy?
Old Aug 25, 2014, 08:17 AM
Zet is offline
Zet
Find More Posts by Zet
Zet
Sweden, Stockholm County, Stockholm
Joined Jan 2012
Could these fit?
http://www.banggood.com/Wltoys-L929L...-p-942714.html
Zet is offline Find More Posts by Zet
Old Aug 25, 2014, 10:57 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Just spotted those gears. Should be the same in the 2019 as I believe it shares its chassis with the L939, L929 etc.
epilot is offline Find More Posts by epilot
Old Sep 30, 2014, 02:04 PM
United States, FL
Joined May 2014
Originally Posted by Zet View Post
Hey, great find! So are these working fine with the 2019 or 929?
EDIT: Order the replacement gear sets, lets see if they fit.
Old Nov 09, 2014, 08:05 AM
United States, FL
Joined May 2014
I forgot to update here.. the replacement gears fits perfectly fine...
Old Jun 20, 2015, 09:07 AM
lollo78 is offline
Find More Posts by lollo78
Joined Jun 2015
SMD component on PCB
Hi guys,
my Wltoys 2019 stopped working.
On the PCB there are 2 SMD components burned (so I can't read the value/code).
Photo in attached.
Could you see on your Wltoys 2019 circuit board and help me to identify it (I see only "A" the other letters are deleted)?
Thx a lot.
lollo78 is offline Find More Posts by lollo78
Discussion Rebranded NineEagles Solo Pro V2? (WLtoys V911) gettinglucky Coaxial Helicopters 1 Dec 26, 2011 01:06 AM
Question EC Declaration of Conformity for WL-V911 2.4G 4-CH RTF Micro Helicotper nick007shadow Electric Heli Talk 1 Dec 23, 2011 04:50 AM
Discussion Which car for beginner? $100 budget: Evader or Mini-T aEx155 Off-road Cars 1 Nov 27, 2011 09:47 PM
Sold losi mini rally car brandonb5269 Cars - Cars and Parts (FS/W) 5 Mar 10, 2011 04:22 PM
