Old Dec 12, 2010, 01:24 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Working with thin ply wood
Does anyone know a good way to cut clean 12mm diam holes through 3mm 3ply sheeting?
I've tried the pilot hole and drill halfway through then come in from the other side methods, but they all result in the drill bit catching and ripping the last bit through rather than 'drilling' per se. Makes for a fairly tatty hole either way.
Any tricks around, short of making up some sort of sandwich jig or 12mm piloted punch?
BJ
BJ64 is offline Find More Posts by BJ64
Old Dec 12, 2010, 01:55 AM
Oneson1 is offline
Find More Posts by Oneson1
Melbourne, Victoria, Oz.
Joined Oct 2000
Sandwich the ply between two pieces of thicker ply, MDF etc, that will drill cleanly, Clamp well, set the drill speed to suit the sacrificial material. and go for it.
oneson1
Oneson1 is offline Find More Posts by Oneson1
Old Dec 12, 2010, 03:26 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Ta 1
BJ
Old Dec 12, 2010, 03:45 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
De ja vu??
Do what he said^^
discostu956 is offline Find More Posts by discostu956
Old Dec 12, 2010, 05:48 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
LoL
You stalking me, Stu?
Thought I'd put it up as it's own thread - didn't really know if I'd get any replies in our usual thread. Shoulda known better...
Turns out that the Spade bits work a treat - after you get the pressure and feed-rate sorted on a few pieces of scrap first.
I prolly should close this thread...
BJ
Old Dec 12, 2010, 06:41 AM
Al M is online now
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
Brad point drills are also good. It is best to use a drill press and high speed with a slow feed.
Al M is online now Find More Posts by Al M
Old Dec 12, 2010, 07:09 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
erm...
What's a "Brad point drill" ??
BJ
Old Dec 12, 2010, 07:11 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Ahhh...
Just Googled it... like a dowel-drill, yah?
BJ
Old Dec 12, 2010, 11:00 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Forstner bit if you use a drill press. Can also cut a segment of a circle on the edge of a work piece.
DT56 is offline Find More Posts by DT56
Old Dec 12, 2010, 10:32 PM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
If using a holesaw, spin it in reverse
invertmast is online now Find More Posts by invertmast
Old Dec 12, 2010, 10:43 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
holesaws are just terrible. if you end up with the right sized hole, it's usually an act of god.
Do yourself a favour and get a forstner bit or spade drill, these work much better in ply than ordinary drills.
I have acutally changed to using these drills for anything above a 1/4" hole
Curare is offline Find More Posts by Curare
Old Dec 13, 2010, 02:43 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Yep - spade drills seem to be the go.
I'm cutting nice clean holes in 3mm ply by using a backing-block, then taking the spade down until I see it just start to cut a full circle, then come back in from the other side to complete the hole. Works a treat...
Thanks guys
BJ
Old Dec 13, 2010, 12:43 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
If you're doing a lot of these holes then re-shaping a spade bit to make it into a special one off mini flycutter might allow you to cut only from the one side. Spade drills can be shaped and sharpened easily with a regular file.
BMatthews is offline Find More Posts by BMatthews
Old Dec 13, 2010, 02:38 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Would you have a pic of such a thing, BMat?
BJ
Old Dec 13, 2010, 03:14 PM
sscherin is offline
Find More Posts by sscherin
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
Forstner and a backing board for a clean exit..
sscherin is offline Find More Posts by sscherin
Discussion Basic wood working. venquessa Electric Plane Talk 8 Oct 15, 2010 02:00 PM
Help! Alternatives to thin ply. Hamburglar Slope 9 Jan 19, 2010 10:29 PM
Discussion Where to buy Balsa and thin Ply? Tshires Slope 7 Jan 17, 2008 08:50 PM
Bulletin: Thin CA soaks right through 1/64" ply astroboy Electric Plane Talk 4 Sep 16, 2002 12:19 AM
