Old Apr 28, 2009, 03:09 PM
gloworm is offline
Find More Posts by gloworm
gloworm's Avatar
LEICESTERSHIRE UK
Joined Nov 2008
belt cp flybars rods by the dozen+feathering shaft damper O rings by the hundred
Next time you need a Feathering Shaft, Damper O Ring, try your local industrial seal supplier .After showing mine a sample, and spending a minimum 5 about 7 bucks I came away with 200. SHOULD LAST A BIT?. the same goe,s when you need Flybar Rods go to your local Cycle Shop and get a Dozen S/Steel 2mm cycle spokes these cost 1.50 about 2 bucks just cut to length . these are also high tensile and stronger than the original you don,t have a thread on the ends , but I have never had any paddles move once setup.they may need to be straightend a bit , but this is easy just sight down there length and bend where necessary.A bit like straightening an arrow shaft, with a bit of practice you will get really accurate ,better than you can buy. HAVE FUN
gloworm is offline Find More Posts by gloworm
Discussion belt cp feathering shaft O ring recess fault gloworm Electric Heli Talk 0 Apr 02, 2009 02:54 PM
Discussion Belt-CP new feathering shaft offered?? Bird-of-Prey Mini Helis 2 Jan 04, 2009 04:50 PM
Wanted EK5-0395 Belt CP/King Upgrade Head Feathering Shaft RobDog Aircraft - Electric - Helis (FS/W) 9 Jul 05, 2008 05:51 PM
Discussion Belt CP King2 carbon feathering shaft and main shaft with reasonable price on Ebay diymax Hot Online Deals 13 Feb 20, 2008 04:18 PM
Discussion Feathering shaft for the Blade CP but no gear tooth??? kushal_22 Micro Helis 7 Nov 22, 2006 04:33 AM
