Old Jul 01, 2010, 08:46 AM
tbird911 is offline
Find More Posts by tbird911
I added lift to my stable!
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
Couple more Aurora questions . . .
Hi All,
Finally finished building out my Mini Ultra Stick and Radian and now getting ready to do the power/radio wiring/setup. Few of questions:
1.) On both planes, I'm using batteries from HobbyKing that have the EC3 connection and a balancing lead. I am also using external BEC for each plane (dimension engineering SportBec for the Mini Ultra and ParkBec for the Radian.) I know many will consider this overkill, considering the SPC function, but I have some future plans and prefer to go ahead and wire it this way. I think I read that I can run the balancing lead to the SPC so that the correct voltage (from the battery pack) is displayed. Anyone give details on how they have their setup?
2.) On the Radian and Aurora: How do you guys, that are Radian pilots, have yours setup? What model type to you choose after Glider?
Thanks in advance,
tbird911 is offline Find More Posts by tbird911
Old Jul 01, 2010, 05:24 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Yes, you can use the balancing port for the SPC; use the two outside wires to a servo connector. Remember that the jumper are not the same connections as the power; it plugs in the same polarity as the servos. Just be careful with the adapter as the pins are very small. I really like soldering the SPC connection to the power plug on the ESC.
MikeMayberry is offline Find More Posts by MikeMayberry
Discussion Couple more DF questions Graiskye Micro Helis 0 Apr 06, 2008 02:20 PM
Discussion A couple more noob questions. Witblitz Fuel Heli Talk 15 Oct 07, 2007 06:48 AM
a couple more questions mhmitchell Scratchbuilt Indoor and Micro Models 1 Sep 08, 2004 10:57 AM
Couple more Tiger Moth build questions fogflyer Parkflyers 8 Sep 24, 2002 09:14 AM
couple more TM questions ;-) AussieParkflyer Parkflyers 2 Dec 28, 2001 10:09 AM
