Old Feb 15, 2013, 01:16 PM
United States, NJ, Caldwell
Joined Apr 2007
Help!
Need a 2mm motor shaft.
Hi. I picked up a small brushless motor for an Old Timer project but it came with a prop saver setup. I want a solid shaft so I can use a regular prop adapter.
Does anyone know where I can get a 2mm shaft from? I did some searches but came up empty handed...
I'm thinking I'll go raid Radio Shack and see if any of the cheapie small motors there have a shaft I can rob.
Sessholvlaru is offline Find More Posts by Sessholvlaru
Old Feb 15, 2013, 01:26 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Here are couple:
http://www.headsuprc.com/servlet/the...aft-for/Detail
Here is a page full of stuff in case I missed one:
http://www.headsuprc.com/servlet/the...FTS/Categories
Here is everything you need to know about fitting and cutting shafts:
Making and Replacing a Brushless Motor Shaft - http://www.rcgroups.com/forums/showthread.php?t=1240725
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 15, 2013, 01:44 PM
Joined Apr 2007
Hey that was fast, thank you!
Old Feb 17, 2013, 09:33 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
RCtimer.com
They have shafts to fit most and in different lengths.
Nigel
solentlife is online now Find More Posts by solentlife
Question Need help determining motor shaft size/replacement Mavs424 Electric Plane Talk 4 Jan 20, 2013 05:55 AM
Discussion need adapter - 370motor (2mm?) to 3mm shaft pglenn Electric Power Cars 0 Jul 03, 2010 06:02 PM
Question Can a spinner made for 3.2mm shaft be used on a 3mm shaft motor? Warsaw Electric Sailplanes 12 Sep 30, 2008 07:01 AM
Turn Down GWS Motor Shaft Spline to 2mm Shaft aplphabandaid Power Systems 3 Jul 29, 2004 05:10 PM
FS: Graupner CAM 6x3 Folding prop - for 3.2mm motor shaft JohnM Aircraft - Electric - Airplanes (FS/W) 16 Apr 08, 2003 06:27 AM
