Old Mar 22, 2003, 10:01 AM
El Queso Grande
Rippin in Hood River, OR, USA
Joined Oct 2000
1400ae in brushless set up?
8 cell 1400AEs for an AXI 2814/10 direct drive with a 30a Jeti esc turning a 9x6 or 10x6 prop. Will this pack take that current or should I look elsewhere. I only ask b/c I have two of these packs already.
This will power my new Super Miss. AUW ~32oz.
windsurfer is offline Find More Posts by windsurfer
Old Mar 22, 2003, 03:39 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I use 8x1400AEs under 18 amps. Anything more and they're getting quite warm.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 23, 2003, 12:42 PM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Mark hit it on the nose with the amp draw capability of the 1400Ae cells. I've used a few of these packs for hundreds of flights in my twin Islander. They work well up to 17-18 amps for 30 seconds to 1 minute or so, then start to fade. I have mine propped at 18 amps and use full throttle only for takeoff and aggressive vertical flight then back off the left stick. Using them in this way has brought several flights over 11 minutes. My last pack finally died when it got wet in a float plane and had 200-300 cycles on it.
I have now switched over to the 1700AUO Nimh cells. They're a few grams heavier, the same diameter, and slightly shorter than the 1400Ae's. The difference is they can be used up to 33 ampos or so.
GregG is offline Find More Posts by GregG
Discussion where to put protection fuse in brushless set up. OETOMO Micro Helis 5 Jun 30, 2007 05:26 PM
Ideal Brushless Set Up! juantrinidad Beginner Training Area (Aircraft-Electric) 4 Jun 25, 2002 12:38 PM
Ideal Brushless Set Up! juantrinidad High Performance 7 Jun 25, 2002 10:03 AM
Best brushless set-up for EPconcept..Hacker C40-10S ? marcusg Electric Heli Talk 3 Jun 03, 2002 08:31 AM
Voyager E - Brushless set-up, almost..! DaveRC Electric Heli Talk 7 Dec 02, 2001 10:43 PM
