Old Oct 29, 2014, 12:21 AM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Oh, man. Sorry to hear it, Pat.
mclarkson is offline Find More Posts by mclarkson
Old Nov 07, 2014, 08:31 AM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Selling off all the kits now (and the one RX-ready F-22 I have is still available.
Get them while you still can!
Kits - http://www.rcgroups.com/forums/showthread.php?t=2278426
RX-ready - http://www.rcgroups.com/forums/showthread.php?t=2278433
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Apr 09, 2015, 04:53 PM
newelectro is online now
Find More Posts by newelectro
Jimmy Rc
newelectro's Avatar
United States, FL, Zephyrhills
Joined Nov 2004
Has anyone built this plane and have it snap roll unexpectedly I have built two and both planes did this with a 500mah 3s battery. Tryed with a 850mah 3s and seemed more stable. I built them with dtf board with paper on auw on one without battery was 6.7 oz both planes are plenty fast they are the 18.8 ws version.
newelectro is online now Find More Posts by newelectro
Old Apr 09, 2015, 08:30 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I've built a ton of them, but never had one snap roll on me unexpectedly. Sounds like maybe your CG is too far back?
Here's where it should be:
Pat
Old May 25, 2015, 04:15 AM
raid is offline
Find More Posts by raid
Joined May 2015
Hi All,
First of all I want to thanks all of you for all the info shared in this post.
I'm a new user, even if I lurk this forum every day :P
I'm flying 250 class racing drones and rc airplanes
Today I want to present my F22 depron airplane :P
Here is my setup:
Body: 3mm and 6mm depron (for the fuselage)
Radio: FrSky Taranis X9D Plus
Receiver: FrSKY X8R receiver (should be replaced by the D4R-II, that is 10g lighter)
Servos: 2x Hitech HS-53 6.2g
Motor: Emax 1806 2280KV (the one for the multirotors)
ESC: Emax Simon Series 12A
Propeller: Gemfan 5030
Battery: Fullpower 3S 460mAh (weight around 45g)
2mm Carbon rod on the wings
1mm steel push rod and two micro linkage stopper and control horns (around 2cm height)
A little 5mm plastic motor mount drilled by myself
Weight: 120g more or less, without battery
All parts glued with 5' Epoxy Glue
And here is a quick video of the first flight. What do you think? :P
F22 RC 3mm Depron first flight (2 min 26 sec)
raid is offline Find More Posts by raid
Sold 3mm White Depron 18 sheets Twinkletoze Aircraft - General - Miscellaneous (FS/W) 1 Sep 06, 2007 09:57 PM
Built up 3mm depron aerobatic/3D??? bcripe1 Foamies (Kits) 4 Sep 03, 2003 08:00 PM
3mm depron CAP MGoddard Foamies (Kits) 3 Sep 01, 2003 07:36 PM
Slice BlueCore into 3mm Depron localbuyer Foamies (Kits) 1 Jul 08, 2003 10:28 PM
For Sale Fs 3mm Depron Sheets CMT1961 Aircraft - Fuel - Airplanes (FS/W) 2 Jan 28, 2003 12:01 PM
