Old Dec 13, 2002, 11:40 AM
fxf is offline
fxf
Find More Posts by fxf
fxf
Fremont CA.
Joined Dec 2002
Is 5A s/c enough for Slow Stick
I Just bought my first RC plane and have been getting great info from you guys on this forum. I chose the GWS Slow Stick. I got what I think is a newer version that has a grey gearbox.
EP-1180 / EPS-300C.
Thing is that the shop sold me a GWS 2045 Flight Pack that has an ICS-100 (5 Amp)Speed Controller. Is a 5 Amp Speed controller enough to handel the EP1180 GW/EPS-300c power unit. The kit also came with a 6 cell NICAD 600MAH Battery.
FXF
fxf is offline Find More Posts by fxf
Old Dec 13, 2002, 03:15 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Welcome to the EZone !!
Yes, that ESC will work fine. Just don't overprop it if you change the prop.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Dec 13, 2002, 06:15 PM
konaboy is offline
Find More Posts by konaboy
Sweden (born UK bred Wales)
Joined Aug 2002
That's the same setup I'm using and it's been ok so far...
konaboy is offline Find More Posts by konaboy
Old Dec 13, 2002, 06:49 PM
GForceStress is offline
Find More Posts by GForceStress
Oxymoron: Rap Music
GForceStress's Avatar
Upstate NY
Joined Sep 2002
Ive been a 8x800mah battery and 1260 prop and 5amp ESC with the 300 motor with no problems. Almost 100 flights!
GForce
GForceStress is offline Find More Posts by GForceStress
Old Dec 13, 2002, 08:02 PM
Sirius is offline
Find More Posts by Sirius
Joined Nov 2002
Will two 1020 Kokam in series work ok with that?
Sirius is offline Find More Posts by Sirius
Old Dec 13, 2002, 11:30 PM
NCC-1701 is offline
Find More Posts by NCC-1701
Joined Oct 2002
Sirius,
You should be fine with a 5 amp and 2 Kolkams in series. Nominal voltage on Kolkams is 3.7 per cell/7.4 for your configuration. Most of the members of my club (myself included) with slow sticks are flying 7 cell NiCad packs and 8 cell NiMH packs and 5 amp speed controllers and none of us have had any problems. Amp draw is a function of the motor and the voltage, and since you'll be running a lower voltage than I am, you should be just fine.
I also read in another post that GWS controllers are conservatively rated.
Rob
NCC-1701 is offline Find More Posts by NCC-1701
Old Dec 14, 2002, 02:09 PM
Flying Taco is offline
Find More Posts by Flying Taco
Flying Taco's Avatar
NRH, TX
Joined Jan 2002
Woh wait a minute. The 5 amp draw on the 1020 Kokams is only for short bursts. Any extended amount of flying at 5 amps may damage them. I suggest that you use 4 1020 kokams, 2 in series, two in parallel. This doubles the amount of amps you can draw plus your pack only weights 3 ounces. Not to mention that you could fly for probably 45 minutes+. I have been flying my Slow Stick with two parallel qualcomm 830 packs and it works great.
Flying Taco is offline Find More Posts by Flying Taco
