Old Jul 23, 2007, 12:11 PM
ejscarfo is offline
Find More Posts by ejscarfo
ejscarfo's Avatar
Long Island
Joined Jul 2007
Tail Motor Mount Removal
I ordered an intergrated tail fin and motor mount to go to a direct tail rotor mount for my HB FP. The stock mount seems like its welded to the tail boom, I can't get it to budge to take it off. Anyone have any tricks on getting this off short of destroying it?
ejscarfo is offline Find More Posts by ejscarfo
Old Jul 23, 2007, 12:18 PM
gravydrive is offline
Find More Posts by gravydrive
4.5 Kilowatts of Awesome
gravydrive's Avatar
United States, FL, Sarasota
Joined Jan 2007
You can either soak the tail end in nail polish remover, or dremel a few slits in the side of the mount. If you choose to soak it, remove it from the solution every few minutes to wiggle it back and forth to break the glue bond. If you use a dremel, cut the two slits 180 degrees from each other, then wiggle the mount, possibly applying CA solvent as you go.
gravydrive is offline Find More Posts by gravydrive
Old Jul 23, 2007, 04:58 PM
TooTall is offline
Find More Posts by TooTall
victim of the system
TooTall's Avatar
Home of the Toledo RC show
Joined Jul 2003
remove motor and wiring and hold the tail in a pot of boiling water , being careful not to let it touch the bottom of the pot...
TooTall is offline Find More Posts by TooTall
Old Sep 12, 2007, 08:48 PM
Lutin is offline
Find More Posts by Lutin
Montreal St. Hilaire, Canada
Joined Feb 2002
where did you get your intergrated tail fin and motor mount helihobby is out you mite have an other place i could order it from...
thank you
Lutin is offline Find More Posts by Lutin
Old Sep 12, 2007, 08:54 PM
mckolit is offline
Find More Posts by mckolit
mckolit's Avatar
Southern California
Joined Apr 2007
thank you
Try bphobbies or towerhobbies
mckolit is offline Find More Posts by mckolit
Old Sep 13, 2007, 09:37 AM
ejscarfo is offline
ejscarfo's Avatar
Long Island
Joined Jul 2007
thank you
you can also try heli-fever
http://www.heli-fever.com/product_in...roducts_id=191
or this other site which has the tail or the whole conversion sold as a kit:
http://eboyztoyz.net/index.php?op=showitem&sku=8327
New GWS combo Fin / Tail Motor Mount Sonic1 Micro Helis 2 May 20, 2004 05:24 PM
Hummingbird/EDP-50 Tail Motor Mount Screws T.J. Kong Micro Helis 0 Mar 30, 2004 10:34 AM
Tail motor mount washers knightwind1 Micro Helis 3 Mar 05, 2004 09:09 AM
How Do I Remove the Tail Motor Mount From the End of the Boom? wannabe Micro Helis 2 Nov 12, 2003 07:17 PM
HouseFly Adjustable Tail Motor Mount Mod jk Electric Heli Talk 3 Feb 20, 2002 05:02 PM
