Old May 22, 2004, 01:28 AM
Wing Zero is offline
Find More Posts by Wing Zero
Joined Dec 2003
Question
Canard CGs
Can anyone explain to me, how I would go abouts finding a C of G range for a canard type model? A fourmula would be helpful. Thank you. -James
Wing Zero is offline Find More Posts by Wing Zero
Old May 24, 2004, 10:21 AM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
A lot of dependencies, best to first make a small (scaled down) chuck balsa model and at least get a starting point for your design.
It will depend on aspect ratio and camber of both foils, distance between canard and wing, planforn (sweep, taper, etc).
I think the usual starting point is about 15-25% of the distance between the wing and the canard forward of the LE of the main wing
I am sure you will get plenty of responses with links and threads covering this one.
Tony.
Antonsoarer is offline Find More Posts by Antonsoarer
Old May 24, 2004, 09:58 PM
Joined Dec 2003
Thanks Tony. The chuck glider is a very good idea. Thanks for the tips and hints. -James
Old May 25, 2004, 12:38 AM
Quacker is online now
Find More Posts by Quacker
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
You can get a fair approximate by first measuring the wing area of both wings. Then measure the distance between the chord points of the main and canard. Then the formula is:
canard area/main area/2 * distance between the chord points. This is the distance ahead of the chord point of the main where the approx. CG is located.
As a sanity check on this, imagine that both wings had the same area. It would seem rational that the CG would be exactly between the centers of lift of the wings.
Q
Quacker is online now Find More Posts by Quacker
Site Sponsor
Old May 25, 2004, 10:24 PM
omega blood is offline
Find More Posts by omega blood
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
Here ya go
http://www.palosrc.com/instructors/putte.pdf
omega blood is offline Find More Posts by omega blood
Old May 25, 2004, 10:44 PM
jhas is offline
Find More Posts by jhas
Brentwood,TN
Joined Mar 2001
Canard pitch control design
In designing a canard, I understand that the forward wing is critical for lift, and essentially sets the stall speed. My question is regarding the design of the canard for pitch control. Initially, I have made the canard with a split in the center as a hinge line, but I am think that it may be very inefficient and may not fly well. The other design is to have the whole canard wing rotate avoiding the hinge line altogether. This would be technically be more difficult to build. Is the hinge line for pitch control going to be a problem? Do you think I will need to change the canard wing to a "full" surface area rotation design?
Jason
jhas is offline Find More Posts by jhas
Old May 25, 2004, 11:13 PM
Joined Jan 2002
Jason
No and no.
Old May 26, 2004, 10:59 AM
chrisgood is offline
Find More Posts by chrisgood
chrisgood's Avatar
Monkton, MD
Joined Dec 2003
I took Ron Van Putte's equations and put them into an Excel spreadsheet a while back. It is here: http://www.chrisgood.com/rcplanes/fwiw/index.html at the bottom of the page. Just enter your values into the yellow areas on the spreadsheet and it will tell you the CG.
Chris Good
chrisgood is offline Find More Posts by chrisgood
Old Jun 13, 2004, 08:34 PM
adam_one is offline
Find More Posts by adam_one
flying low & slow
SE
Joined Mar 2003
Chris Good
Hi,
I've checked your Excel spreadsheet and notice an error at the canard P calculation.
You have entered (R*T) at far right of the formula as shown below:
The correct formula is:
P(canard) =(L x S(tail)) / S(wing)) + (1/15) ( (R^2 + RT + T^2) / (R+T) )
The formula you've entered in Excel is:
P(canard) =(L x S(tail)) / S(wing)) + (1/15) ( (R^2 + RT + T^2) / (R*T) )
You might wish to make an amendment.
adam_one is offline Find More Posts by adam_one
Old Jun 14, 2004, 07:50 AM
chrisgood's Avatar
Monkton, MD
Joined Dec 2003
Thank you. Good catch! I have made the correction to the Excel spreadsheet and reposted it to my website.
Now I need to go back and recalculate the CG for one of my canards.
Chris
Old Jun 25, 2004, 12:01 AM
vinican is offline
Find More Posts by vinican
Joined Feb 2004
Jason
One thing to keep in mind Jason, is surface deflection creates DRAG.
The more a control surface is deflected from centered, the more drag it creates. Especially on the pitch axis, this induced drag can cause a problem.
If the canard is only say 2 inches from the CG, but the TE of the main wing is say 6 inches from the CG, It might be better to use elevon mixing with the main wing, as the ratio of Pitch force to Drag force created by the elevons might be more desireable than using the canards for pitch. This is because the amount of force required to create a given pitch change using elevons would be 1/2 the force required to create the same pitch change using the canards, at least in the senario I mention. Less force = less induced drag, which is a good thing, usually anyway(exception explanation follows).
You still might want to use the canards as FLAPS, because in that case the drag induced would be desired, and the pitch movement is NOT desired, and is lessened vs elevons.
vinican is offline Find More Posts by vinican
Old Dec 03, 2005, 04:34 PM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
ron van putte
hi
i came aross this post while looking for a canard c of g calculator
can you help me i must be doing something wrong
i have tried to work out a c of g for a canard with a nearly identical forplane to that of the wing
the answer i get must be wrong as its just in front of the ac on the canard yes the canard
thinking it was the way i entered it into my calculator i downloaded the excell version from the link in a previous post and i still get the same position
try putting some figures into the spread sheet with similar wing and canard sizes
i think the LS/S on the P calculation should be divided by 2
all the best
kev
kdwzagi is offline Find More Posts by kdwzagi
Old Dec 04, 2005, 02:35 AM
adam_one is offline
flying low & slow
SE
Joined Mar 2003
Hi,
I don't think your math is wrong.
The trouble is that your plane is more a tandem than a canard.
The formula used for the canard CG may only be valid to Foreplanes areas ranging from 15% to about 50% of the aft Wing area.
In your case, you may try using the following formula to find NP (Neutral Point) as % of the Wing's MAC forward of Wing's AC:
NP = Distance between ACs * Foreplane Area / ( .8 * Wing Area + Foreplane Area)
Then add about 10% Static Margin to the result in order to get a 'safe' CG location.
I think that will put you on the ballpark.
But if you're not so keen on formulas you may use the following calculator:
Canard CG Calculator
Good luck
Old Dec 04, 2005, 06:31 AM
kdwzagi is offline
(madkev :) )
kdwzagi's Avatar
Joined Dec 2002
canard
thanks
i thought i was going mad
kev
Old Dec 04, 2005, 06:55 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Originally Posted by kdwzagi
hi
What is the 'ac' - not the whole aircraft...? surely?
I woiuld say CG on a pair of almost equal planes would be somewhere around the TE of the foreplane.
all the best
kev
Make up a chuck glider of depron and try...if you mistrust the calculations.
