Old Jan 08, 2002, 09:20 AM
JimF is offline
Find More Posts by JimF
Ellington, Connecticut, United States
Joined Apr 2001
Please recommend DMM/Whattmeter
I'd like to purchase a whatt/amp/voltmeter that does everything I need. Much preferable to buying something and getting a bigger/better/different one soon after.
I have the Hitec CG-335 charger, which I thought had some sort of meter (digital display), but I guess I need more than that.
Jim
JimF is offline Find More Posts by JimF
Old Jan 08, 2002, 09:23 AM
JimF is offline
Joined Apr 2001
Can't spell
Ok,
My physics professor used to ask, "Watt is the unit of power?"
Never did he ask "Whatt is the unit of power?"
The spelling has been changed but the question remains.
Jim
Old Jan 08, 2002, 10:31 AM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Watt meter
Get the Astro flight Watt. Best tool you will have!
Bob Ruff
bruff is offline Find More Posts by bruff
Old Jan 08, 2002, 11:16 AM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Astro watt meter
JIM
I'll go along with Bob, Get the ASTRO watt meter, GREAT Tool
JOE
uncljoe is offline Find More Posts by uncljoe
Old Jan 08, 2002, 05:34 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Watt is so great about the Astro? Dose it measure inductivly or do you have to break the circuit? What all can you do with it and how much is it?
I currently measure the load voltage with a DMM and use an inductive Ameter to measure current with another.
JasonJ is offline Find More Posts by JasonJ
Old Jan 08, 2002, 10:19 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
astro flight watt meter
jason
I guess the reason that the Astro Flight watt Meter is so Great is that It works . No brainer, goes between the battery & load( controller) Displays watts/volts/ current at same time .
If you only have one measuring tool for Electrics, This is # One.
Joe
Old Jan 08, 2002, 10:56 PM
JimF is offline
Joined Apr 2001
Astro Flight Whattmeter
The Tower hobby tech notes on the Super Whattmeter say that the Zero loss connectors must be used. Of course if there is loss across a connection, then your measurment is erroneous. Is there any reason I can't put Sermos connectors on the whattmeter?
While we're on the topic. The folks at EAM suggested the sermos. Note: Everything I've read about EAM, AND MY PHONE CALLS, QUESTIONS AND PURCHASE FROM THEM HAS BEEN GREAT. What do y'all use? Are there connectors that are better/easier/cheaper?
Jim
Old Jan 08, 2002, 11:04 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Connectors
I use Sermos on my Watt meter.
Bob Ruff
Old Jan 08, 2002, 11:53 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
watts
i also use sermos connectors
Joe
Old Jan 09, 2002, 10:57 AM
JimF is offline
Joined Apr 2001
Alright! At least I'm doing one thing right!
Jim
Please recommend a prop for GWS Tiny and 010 Astro on 3 kokams poobs Parkflyers 6 May 02, 2003 11:12 AM
Gary Wright - Please Recommend Logo 20 Setup crashman Electric Heli Talk 9 Aug 23, 2002 08:32 AM
GWS R-4P, a little bit disappointed. Please recommend other light weight rx gear. ericss Parkflyers 33 Dec 27, 2001 05:09 AM
Please recommend power rorywquin Power Systems 1 Oct 29, 2001 07:24 AM
Newbie in Slowflyer, please recommend kits Magna Parkflyers 6 Jun 19, 2001 02:35 PM
