Old Dec 08, 2013, 04:46 PM
mark70 is offline
Find More Posts by mark70
Joined Mar 2007
Storage charging a 2s none balance lead battery on MPA
I am sure there was a thread on this saying I can be done but I cannot find it.
can anyone help
Thanks.
Mark
mark70 is offline Find More Posts by mark70
Old Dec 08, 2013, 10:14 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
What packs are we talking about here? What kind of a connector or connectors are on the pack?
Gregor99 is offline Find More Posts by Gregor99
Old Dec 09, 2013, 04:04 PM
mark70 is offline
Joined Mar 2007
Gregor
F3P packs 120 or 180 ma. Mainly Hyperion but also Glens Ace only connectors are JST mini plugs no balance leads
Mark
Old Dec 09, 2013, 05:12 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Forgot to ask which charger. If you have a Powerlab6 you can use the Preset I created for this purpose. You will need a parallel cable, or adapters to go from the MPA to your packs.
http://www.rcgroups.com/forums/showthread.php?t=1837319
If you have a Powerlab8, I can create a second preset.
Old Dec 10, 2013, 01:15 AM
mark70 is offline
Joined Mar 2007
Sorry I should have given fuller details. powerlab lab 8 with the MPA board. 120 to 180 ma 2 cell lipos with no balance leads charging up to 6 at a time
Many thanks
Mark
Old Dec 10, 2013, 01:59 AM
Gregor99 is offline
Seattle
Joined Sep 2007
I put the PL8 storage preset in the FAQ thread above. You will be limited to a charge rate of 2 amps for safety reasons.
Old Dec 10, 2013, 04:04 PM
mark70 is offline
Joined Mar 2007
Thanks Gregor. Silly question how do
I load it. I have the cable to attach the powerlab to my PC. Do I just look for preset files and copy in?
Sorry to be a pain
Mark
Old Jan 03, 2014, 02:28 AM
mark70 is offline
Joined Mar 2007
I cannot see how to load the new preset. I have hooked up the charger to my PC but the existing file looks like a different format. Can anyone supply an idiots guide of how to load
Mark
Old Jan 03, 2014, 07:52 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Connect the CCS to the Powerlab. In the CCS, select the target preset where you want to load the new present. Then on the file menu select "Open File to Preset ##" Browse to the file and download it. Note there is a PL6 version (file extension PS6) and a PL8 version (file extension PS8). Once the preset loads, select "update to write the changes to the charger.
Old Jan 06, 2014, 03:11 PM
mark70 is offline
Joined Mar 2007
Thanks Gregor. My computer was saving it as a text file. Sorted and loaded. Many thanks
Mark
Old Jan 08, 2014, 08:51 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I also created myself a 1s/2s unbalanced storage profile in order to storage charge my 1s cells. Would be really nice if they would just include that profile by default in a CCS or firmware update.
grimbeaver is offline Find More Posts by grimbeaver
Mini-HowTo 2s balance lead solution Knife Liddle Micro EDF Jets and Power Systems 0 Dec 08, 2013 02:46 PM
Sold 2s, 3s, 4s, 5s, & 6s Balance Charge Leads TGKconnectors Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 19, 2013 09:54 AM
Help! ACCUCEL-6 Charging with-out balance lead? georgy Batteries and Chargers 3 Oct 09, 2013 10:24 AM
Wanted 130x battery lead or 2s balance female connector or bad board FlyingJFPV Aircraft - Electric - Helis (FS/W) 4 Oct 07, 2013 04:22 PM
Question Charging via the balance leads CNY_Dave Batteries and Chargers 7 Sep 28, 2013 03:41 PM
