Old Sep 10, 2013, 02:17 PM
LostVisual is offline
Find More Posts by LostVisual
Launch high, go long
LostVisual's Avatar
Boise, ID
Joined Sep 2006
Originally Posted by lincoln View Post
3M book tape has been recommended for this use by other flyers. I've got some and it seems quite substantial. I favor polyester tape with an acrylic adhesive. Takes a day to reach full strength but sticks harder.
If you're paranoid, you can do the ends of the control surface and/or the area near the control horn with s-hinges:
http://www.modelaircraft.org/mag/ftg...1/31main2.html
You could also do the whole hinge that way. If done correctly, these are very tough.
I'll look into those tapes. I'd forgotten about the s-hinge. Excellent idea! The plane I'm assembling already has drooping flaps from the manufacturer. This is on the inboard end only of both flaps. Don't know if it is the tape not holding or warped balsa but they drop 1.5-2mm.
LostVisual is offline Find More Posts by LostVisual
Old Sep 10, 2013, 02:39 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You could also make the hinge from the covering material itself if you are covering the wing.
I've done this even on faster slope planes with sheeted foam cored wings. Just do a single-bevel hinge, and make sure to add (3-4) 1" wide strips of covering on the "open side" of the bevel, with the covering just hitting the underside of the straight covering, and you should be good.
Hopefully you can understand what I'm referring to.
You end up with an invisible and sealed hinge line.
R,
Target
target is offline Find More Posts by target
Old Sep 10, 2013, 02:58 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Alright, I will chime in here. I was one of the guys suggesting 3M 600 tape as it has worked for me for years. I replace it about every two years. I also only tape one side, including flaps that have the most movement.
So since I didn't win the Montana Summer ALES contest I understand the hesitation to use my suggestion. Ha ha.
So I suggest use all the different methods on this one model and report back with your results.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Sep 10, 2013, 04:55 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
The 600 tape is good stuff also. I have used that succesfully as well.
R,
Target
Old Sep 10, 2013, 05:59 PM
LostVisual's Avatar
Boise, ID
Joined Sep 2006
Curtis -
I wasn't discounting your suggestion on the 3M 600 tape. It appears to be the most cost effective choice. The model already has taped hinges from the mfgr. I am 'exploring' the practice of tape hinges as a builders method as well as alternatives because of the drooping inboard end of each flap and a concern about possible flutter if the tape gets loose/sloppy.
Another take away, check the condition of the tape periodically and replacement is easy.
Old Sep 10, 2013, 07:29 PM
Red Merle ALES
Joined Apr 2002
Mike,
I think it has been a great conversation and thread.
Curt
Old Sep 11, 2013, 04:19 PM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
I've used Sellotape Diamond on competition mouldies to repair / replace peel-ply hinging. I've used 3M Book Tape too although Diamond is thinner and just as reliable.
Silicon is aerodynamically purer but offers more resistance to the servos than tape.
If taping, I recommend taping on both sides of the hinge line although just use shorter strips on the side that's mostly concealed and especially at the ends and where the horn sits.
The gain in hinge strength / pivot accuracy by doing this is worth it IMHO.
DrFragnasty is offline Find More Posts by DrFragnasty
Sold 3 rolls 3m blenderm 1" x15' hinge sealing flexible foamy tape $12 shipped mdtang Aircraft - Electric - Airplanes (FS/W) 5 Apr 12, 2013 11:32 AM
Sold 3 rolls 3m blenderm 1" x 15' hinge sealing flexible foamy tape $12 shipped mdtang Aircraft - Electric - Airplanes (FS/W) 0 Mar 27, 2013 09:44 AM
For Sale 3 rolls of 3M Blenderm hinge tape mdtang Aircraft - General - Miscellaneous (FS/W) 3 Mar 27, 2013 07:55 AM
Discussion Tapes used for hinging for indoor planes (brand names) byrocat Scratchbuilt Indoor and Micro Models 20 Oct 12, 2012 02:24 PM
Using Hinge Tape As Opposed to Hinges on speed 400 and 600 planes Joe Elston Electric Plane Talk 21 May 16, 2001 05:20 PM
