Old Aug 26, 2013, 04:21 AM
Hot Air Dreamer is offline
Find More Posts by Hot Air Dreamer
Chris Nifty
Joined Apr 2013
Strong stick spring tension?
Hey guys, as I read on here a little while ago some like strong stick spring tension on the tx. Is this specifically good for dlg, or any soaring?
Hot Air Dreamer is offline Find More Posts by Hot Air Dreamer
Old Aug 26, 2013, 06:13 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
I run it on all my gliders,
I find it really helps me to be smooth and accurate. Note that I am a thumbs-on-top flyer and that I have very large hands.
When I give my Tx to someone else to fly, they usually give it back pretty quickly.
Of interest, the place I bought the heavy springs from said they are intended for pattern flyers, to give more accurate control and reduce unintentional cross-controlling.
Try it and see, it's a cheap mod and easily reversed.
Ken
skyboyken is offline Find More Posts by skyboyken
Old Aug 26, 2013, 06:51 AM
Triggerhappy is offline
Find More Posts by Triggerhappy
United States, NC, Zebulon
Joined Apr 2009
Ken
I also tightened mine up (after reading the same post), and I like it allot better. But my stock springs only go so far, especially on the one stick.
Is there a site to get heavier springs for a variety of radios, or do I have to go through Spektrum (H.H.) for my dx6i?
Triggerhappy is offline Find More Posts by Triggerhappy
Old Aug 26, 2013, 06:59 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
My spring tention is as soft as possible on my dx7s, when you are relaxed enough you can make small movements and use the full resolution of the sticks!
Before I throw my plane in the air I'm looking around me, control my breath (like freediving the other hobby) and if I am relaxed and standing strong than I throw my plane.
Just try it, the mindset is way more important than the tention on your sticks!
And the other thing is: its an hobby not a sport ;-)
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Aug 26, 2013, 08:43 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Personally I like strong spring tension for every type of flying. Why? Because I like the tactile feedback I get for center with the strong springs. It takes a little getting use to but once you do, you never go back to soft springs.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Aug 26, 2013, 08:45 AM
brs608 is offline
Find More Posts by brs608
brs608's Avatar
United States, LA, New Iberia
Joined Nov 2011
Radio south R/C has the stiffer springs. That's where I got all of mine from.
brs608 is offline Find More Posts by brs608
Old Aug 26, 2013, 10:13 AM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I need some stronger springs for my 9303. Every radio I get I immediately crank up the spring tension to the max.
davidjensen is online now Find More Posts by davidjensen
Old Aug 26, 2013, 10:40 AM
Joined Apr 2009
Thanx.
Old Aug 26, 2013, 02:14 PM
Chris Nifty
Joined Apr 2013
Ok, thanks guys, I'll try it.
Old Aug 26, 2013, 08:21 PM
JimZinVT is offline
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
And shorten the sticks all the way too!
JimZinVT is offline Find More Posts by JimZinVT
Old Aug 26, 2013, 09:21 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
+1000
Shorten and stiffen the springs, remove expo on all my sailplanes.
tom43004 is offline Find More Posts by tom43004
Old Aug 26, 2013, 10:09 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
If you can't easily tell where the sticks are being held by feel, you can't be sure of the input being given to the sailplane. And if you can't be sure of the input given to the sailplane, you can't read the air very well while giving input to the sailplane...
Stiff springs give the tactile feedback that aids in knowing and controlling the stick position - even when walking and moving around.
Also with very soft spring settings, long sticks may have enough inertia to move the sticks slightly during the throw. Or if one uses a thumb to hold the flap stick up during launch, it is easy to unknowingly put in a bit of rudder by accident.
Gerald
G_T is online now Find More Posts by G_T
Old Aug 27, 2013, 01:40 AM
Chris Nifty
Joined Apr 2013
I'm going to have a dedicated tx for sailplanes, so if I customize it with strong springs and maybe shorter sticks, is that going to stuff with my thumbs/brain when I go to fly my helis with another tx?
Old Aug 27, 2013, 01:49 AM
Chris Nifty
Joined Apr 2013
Ha ha ha, wow, I just unscrewed the right stick knob off my DX6i and tried it for rudder & elevator and it actually feels pretty good like that - a lot more feel and I can feel much more spring tension that way.
Old Aug 27, 2013, 09:58 AM
Will fly for food
Bellevue WA,
Joined Dec 2003
How could you fly a heli without the stick tension cranked all the way up? I never could.
Discussion 9XR Stick Tension mcashatt Radios 5 Apr 08, 2014 06:01 PM
Discussion Devo 8s stick tension PurpleShark Radios 0 Jul 19, 2013 11:32 AM
Discussion Jr X9503 Stick tension adjustment Wingin' Wayne Radios 0 May 19, 2013 08:09 AM
Discussion dynam stick tension lardo5150 Simulators 0 Jan 06, 2013 08:33 AM
Discussion Transmitter Stick Length and Spring Tension chris1379 Radios 8 Feb 01, 2012 09:16 AM
